The lens is really sharp and is up to the standard that Olympus has already shown us with the M.Zuiko 12-40mm f/2.8. At the centre, we didn’t notice any decrease in sharpness throughout the entire zoom range and from f/2.8 up to f/5.6. If we start to pixel peep a little more, we can notice that at f/8 there is a slight loss in sharpness especially at the longer focal lengths. From f/16 up to f/22 there is some diffraction too, which is nothing out of the ordinary for a Micro Four Thirds lens.
http://www.mirrorlessons.com/2015/05/28/olympus-7-14-2-8-pro-review/
The Olympus 7-14mm f2.8 is another great lens for the Micro Four Thirds system. It manages to match or outperform the detail delivered by the already excellent Lumix G 7-14mm, while boasting an extra stop in aperture, the benefit of weather-sealing, and banishing its issues with flare.
http://www.cameralabs.com/reviews/Olympus_M_Zuiko_Digital_7-14mm_f2-8/
Image quality is excellent. Centre sharpness is very high throughout its focal length range, although the performance drops off a little at the edges, where you really need to stop down to at least f/4 to get acceptable results. Chromatic aberrations are well controlled, vignetting is present but not a real issue, and distortion is very well auto-corrected
http://www.photographyblog.com/reviews/olympus_m_zuiko_digital_ed_7_14mm_f_28_pro_review/
7mm
14mm
During testing this lens proved itself worthy, by delivering images with outstanding sharpness, whilst handling well and sporting a robust dust and moisture resistant construction.
http://www.ephotozine.com/article/olympus-m-zuiko-digital-ed-7-14mm-f-2-8-pro-review-27761
For a bright ƒ/2.8 lens that's also an ultra-wide angle zoom, the Olympus 7-14mm comes through with flying colors in the sharpness category for the most part. Though the corners are noticeably soft at ƒ/2.8 the wider you get, the center sharpness throughout the zoom range is tack-sharp, even wide-open.
Can you mount a filter on it?
