So, I previously had the flowmotion 2.02 hack and tried to shoot at 720p 60fps with a 64GB 80mb/s sd card, but the write speed wasnt fast enough and recording would stop after 5 seconds. Now I switched to the sanity X patch and my cameras keeps crashing everything time I try to shoot at 60fps 720p on the same card. Any suggestions on a good and stable hack for 60fps 720p ???
https://www.sdcard.org/downloads/formatter_4/
The tool will take a long time to format the card properly.
Seriously, try a different card. We've been through this so many times over the years. One thing we've learned is that ALL cards can fail. It doesn't matter how expensive they are or what speed they're rated at, or what brand they are. They can all fail (and do). Even new ones. As for Sanity, 720 60P is rock solid and works fine with old Class 10 SD cards. Super speed cards are not required.
please try:
http://personal-view.com/talks/discussion/comment/194204#Comment_194204
download the file called: apefos_the-end_nr4_all-gop-versions_pal_ntsc_02april2015.zip
load seta to camera and try, after try it, if you want more datarate try sete.
for more information about it read first post: http://personal-view.com/talks/discussion/12684/the-end-nr4-stable-high-intra-gh2-patches-03282015-by-apefos/p1
