We just did the same test on a NTSC GH2, same result. Does this happen only with 320? Or is it possibly a problem 'going up' to other ISOs as well? Will keep testing.
I can confirm this bug. I just tested with driftwoods 176 GOP1 quantmebaby. I had the same exessive noise at ISO 320 when i tested ISO's sequentially, going from 160 upwards (up to 800).
I then jumped back down to 400 and then did a second at 320 and the exessive noise was "GONE".
I have a PAL camera in PAL-mode. Peculiar indeed. :/
I hear you nomad, I'm wondering why he wrote that since the example here actually shows ISO400 producing less noise than ISO320....strange. I need to check this out.
@v10tdi It's only strange that the guy in that test wrote: "ISO 320 might be the "sweet setting". More sensitive, minimal loss of image quality." Do we have that much variation in the cameras?
If Ralph_B or someone else capable of recording HDMI out compare to 176 GOP1, this would help.
@Isaac_B I agree, there's nothing wrong with how the hack is dealing with noise. Higher bandwidth (less compression) is why we see it. Now the odd changes in noise levels through ISO change, that's another story...
I definitely find the noise higher with the 176 GOP1. Actually, I think the 132 Driftwood hack visually looks more rich and better to my eyes than the GOP1, it looks thicker and the color more accurate. Maybe it's due to bandwidth, I'm not sure.
@Gabel was this a Panasonic len used? I've always had a suspicion (even before the hack) that Pana lenses contibute to the noise we see. But it was just a thought.
@proaudio4: To me, it reminds me of when using settings based around 125 on Canon's, which had noise levels where one could go from 250 to 320 and get a huge difference in noise.
@Ian_T: I did notice 320 being rather noisy at 66mbit, but I'm having a theory that the hack could be the cause of "changing" native ISO.
This might be a dumb question...but....I wonder what the noise would look like at some of the other hacked settings? Could some of this "tweaking" we are doing to the codec have an adverse effect on the noise?
The good news is our noise testing is now atleast more accurate over the stock lower quality firmware settings.
I understand what LPowell and others here are saying, I just can't understand what we are seeing here> how a higher ISO setting 400 produce considerably less visible noise than 320. WTF, over
Also, is there really anyway code wise to really lower the noise levels at a given ISO. I certainly can not think of a way short of post processing which degrades the image.
@Gabel do you have a PAL or NTSC camera? it's an important question for me to determine if the awful horizontal band that occurs in the lower 2/3 of the image has anything to do with PAL or NTSC . I have a PAL gh2 and the horizontal band is a big problem for me sometimes. It is the same banding that is apparent in your test from iso 1000 and above, clearly visible from 1250 onwards, I guess y'all can see it. It is a very annoying problem to say the least since any underexposed areas in your footage to cross that lower 2/3 band and you may have a serious problem. This issue is much worse and evident if the underexposed area is white or sth other than black. The only way of fixing generally this issue is by crushing the shadows in post which you normally don't want. needless to say of course that when this banding appears, it also negates the possibility of lifting shadows.
FWIW - here is a link to fairly comprehensive GH2 noise test done earlier this year - but from still perspective rather than video. Interesting observations that might be relevant in video context. Interesting horizontal lines in some of the pictures. :-)
