http://thenewcamera.com/canon-cinema-c700x-image-and-specification/
For high bitrates difference between MPEG-2 and H.264 is very small.
MPEG-2 has huge advantage (as it is simple) if you use high bitrates
I shudder to think about how high those bit rates really need to be to equal a good H.264 implementation at 4K resolutions.
sounds interesting but.... 10bit mpg2 long gop!!!!!!!
First - it is rumors :-)
Second - MPEG-2 has huge advantage (as it is simple) if you use high bitrates. Improvement of new encoders are focused mostly on efficiency in lower bitrates. Same for Long GOP - if your computer/editor works perfect with it - long GOP is much better than I frame only, as it is much more efficient.
but we put a 4k global shutter sensor for your pleasure
they are strage as usual.
