@PerryWilson the Vagabond sollution looks interesting and economical, but I don't quite understand how it's connected to a GH2. I cant't see a 9V (or similar) output from the Vagabond? Or do you plan using the Panasonic AC adaptor connected to the Vagabond? That would seem a little too bulky to me..
That looks really good, and would act well as a counterbalance on a shoulder rig too. 130W/h should give around 18 hours continuous usage :-D. All I need now is a 3TB SD card and I'm set.
The best bang for you buck and I have been using it like crazy and will soon be making a rail mount for it... is the Vegabond mini from Paul C. Buff... 120v 130watthours and they make a Euro model too (whatever voltage that it). The unit with one battery is $239 and swap-able battery packs (use one charge one swap system) are $89.... http://www.paulcbuff.com/vagabond.php
Here's a little solution i adopted for my gh1 (but it should work with gh2 as well - would just need to replace the DCC3 ith DCC8 coupler) to power it up from V-lock batteries. It can also power the lights and whatever you have at the same time. All with one battery and it will still run for ages. So it's basically this: http://www.ebay.com/itm/DSLR-BP-battery-Power-supply-V-mount-/270822043311?pt=US_Camera_Camcorder_Accessory_Bundles&hash=item3f0e406eaf that a friend of mine adjusted by adding 9.2V output (as i'm not very good with electronics/soldering myself).
Although not a pro-rig solution, I have been using an XPAL 18000 and the DC couple to great effect for a bit now. I must average around 10 hours of usage with it. It's got a 9-12v auto sensing rail, so won't over power. It also has a 5v USB and 14-19v rail for other equipment (although it's designed for laptop use).
I made a little YouTube video of it a while back
Appreciate it won't be of use to everybody, but it's a neat little unit if your considering a consolidated power device for gadgets and filming. I just rig it up using cable ties.
Greetings, we were told about this thread concerning the GH2 power options, so I checked it out :-) As No_SuRReNDeR already mentioned earlier, we make several adapters designed specifically for this great camera. The "Power Plate" solution allows to use common DV batteries as a source of power, the DC converter device powers the camera using any 12V-25V DC power source, so any battery that you already own, including car power, can be used. Please feel free to either post a question here of contact us directly, if have any specific question or a suggestion, will be happy to help with an answer/ custom solutions to your needs. Alex Dolgin Dolgin Engineering http://dolgin.net/Power-Lumix.htm
@Retina For the GH2 DC coupler you need a DC power connector with a 4.75mm outer diameter and 1.7mm inner diameter. It's possible you could find an adapter, depending on what kind of connection you need on the battery end.
You want to solder the center pin (which is the shorter of the two contacts on the soldering end) to positive and the outside cylinder (longer contact) to negative. Use a pliers to crimp the tabs (at the end of the long contact) around the wire to hold things in place and you're good to go.
Saw other topic,.. what is the deal with this? Its a Li-Ion battery pack, but includes 2 outputs and an inbuilt current regulator?
Any ideas how long it would power the GH2 for?
Probably is the easiest way to power the GH2 if it works well... any one used or is it still too new?
Eneloop does have a very good name when it comes to batteries,... and unfortunately - like everything specs can lie so - so don't believe everything that batteries say...
This baby is the whole deal (charger included) for the same price of ONLY a Sony DV (Brandname) battery.
It's designed to plug into a 12v car accessory jack, but you can easily snip that off and attach whatever plug you need for your battery or battery distribution system. On the other end it comes with a bunch of different DC power plugs which are interchangeable, one of which fits into the GH2 DC Coupler (DMW-DCC8). The device has a switch for 5v, 6v, 8.4v, 9v, and 10v output (9v seems to work best for the GH2). I think the maximum current is 3 amps, but that should be enough for the GH2.
was wondering on powering the GH2 when it gets here... I am a DOP on set all day sometimes for multiple days, and the factory batteries just wasn't going to cut it... BUT, being a professional photographer I have some interesting tools at my disposal (p.s. many of which are cheaper and more powerful that switronix and anton Bauer setups) also there is some interesting info about the power inputs. I will folow up on this when I get in my gear, I order next week monday and will be testing in FULL the day it arrives.
I have a nice IDX battery system with 12v power tap. Is there an affordable, turn key regulator I can use to bump my voltage down to 8.4 volt for my GH2? Ideally I'd like to have something that has a few outlets so I can also power my 12v LCD.
I've contacted the seller, he'll put up on ebay soon. He oso mention his modified battery grip(not sure about external battery) can show battery level in GH1 and currently in an effort to do that in GH2.
The battery and the coupler have arrived (for a while now). I tried to find a suitable adapter, but the guy at the electronics store told me the connection on the coupler side is not a common size. It would be cool if we could find out the precise type of connector to see if we can find an adapter. Otherwise, I guess we're stuck with soldering and checking polarity, right @Ptchaw? :-)
@Ptchaw the battery you linked was ~$24 on ebay when, a few months ago.
I'm glad to see the idea embraced here, that battery has everything you need beside the connector. It's a lot less trouble than building your own voltage regulator and battery housing. :)
@No_SuRReNDeR No worries. But you're right, you do need to be careful! The Dolgin looks like a good solution if you already have batteries and has a charge meter.
