@proaudio4 Yep, and quite a major one, most of my shots today were indoor and talking heads, the outdoor detailed shots which are the ones I just got onto working with properly are duff. I'm fixing/testing/rebuilding the patch now, because I WANT a GOP 3 AQ3 at a lower bitrate. If I have to I'll upshift and make an 88M AQ3 GOP3.
Stray, Sounds like it - as you mentioned Chis's post (and driftwoods feedback) regarding average bitrate exceeding max bitrate. Damn, maybe it's worth it to just find the sweet spot by raising the bitrate as you mentioned (100-130Mb/s).
@proaudio@bkmcwd Woah, my bad, not paying attention, or more accurately not remembering http://personal-view.com/talks/discussion/comment/18257#Comment_18257 Soo.. although streamparser is not saying framerate is halved, maybe there is something else wrong. Yeah, there is, framerate is duff on the shots that exceed the max bit rate. Sooo.. it needs some serious alterations to the buffers or you up its max bitrate to 100-130Mbps. Christ I'm really sorry I missed that, but as an example a 31 second shot is actually only 21 seconds running at 23.976. er.. oops..
"I think i'm becoming a firm believer in the visual difference and smooth frame transition that intraframe offers over long GOP."
haha, I'm getting there too working with this GOP 3 footage today, however I'm going to wait a while before really going for GOP 1, I need to overcome some personal concerns first (and it isn't just card/disk space related, I transcode or work mostly with exported still sequences anyway). I'm an old coder and systems designer so for me, although it is obviously working, making a codec built for long GOP run intra just... well.. it makes me itch frankly ;). I feel the same way about how it looks on vimeo too as it goes.
"just amazing" is correct. Thanks for sharing this. Also, is it just me, but even compressed vimeo of driftwoods GOP1 makes it look like it came from a much higher end camera. I think i'm becoming a firm believer in the visual difference and smooth frame transition that intraframe offers over long GOP. freaking love it! smooth-as-fuck is right!
@driftwood thanks for the help, but this is bkmcwds patch not mine, its working really well only the P-Frame to do to it I reckon (but bkmcwd may have other plans). Have a good shoot mate.
Also, you bring up a good point about "hanging on the edge" of being able to write to SDHC cards. Based on the small difference between GOP1 192M and GOP1 176M, the i-frame difference is a bit less than 10%, so maybe it's worth staying at 176M GOP1 and fine tuning for staibility at extremes.
Can the current 176M GOP1 withstand pappas death chart at SS 1/1600 and ISO3200? Anyone know? I'll be testing this tomorrow, but based on driftwood is still fine tuning it, it probably does not at this time.
@Stray if I remember I did a quick look at my old gop 3 132m and stuck 2 on 1080p encoder setting 1 and it worked. Best of luck getting your GOP3 patch fully stable - sounds brilliant and look forward to using it on my return.
@bkmcwd@proaudio4 Ignore my previous concerns, I've just spent a few hours working with the footage I shot today with this 66M GOP3 AQ3 patch and all is good, very good. I also can see little point trying to squeeze more juice out of the I-Frame size either, it's not worth the effort as you won't be able to push it much higher than it is already. As it goes it's delivering a great bitrate and lovely looking streams under many different conditions/shots. The only thing to do is to kill that rogue P-frame, I'll try what @driftwood suggested to change with the encoder setting tomorrow, but I guess you will too.
I get what you're saying proaudio4 about pushing for a 192M GOP1 but on the downside of that is it may further limit the type of SD cards that can cope with it (and cause even more twitchy fear in those who point it at a very highly detailed scene for any length of time ;)), and after all this 176M GOP1 is sweet as as it is really (but yeah, you need a very good card to run it anyway, which is fair enough frankly). Also, diminishing returns, gilding the lily etc.
I'm away this weekend in Paris filming so its not looking likely I'll have time to finish the latest patch till Sunday night. PS: Vitaliy will be glad to be rid of me :-)
@PerryWilson no, its using more Q settings (and I havent released those WIP settings yet) - but I need to adjust and it could mean limiting a bit more... :-(
