Sure, as soon as I can get a decent web connection. In a couple of days...
@frullaccia please can you elaborate the benefits and your perceiving of the image quality in the nebula-workhorse? thanks.
Wonderful achievement! I also recommend the nebula-workhorse set!
@apefos 720p - 95mbs Card with i-dynamic on = No Spanning 8minute recording. With i-dynamic off = No Spanning 8 minute recording time. For me that's good enough when I know I'm getting the best 720p quality ;) I will definitely share as soon as I'm done with video..
@TrackZillas just a question if you allow me: did you get the boson 720p SH spanning in the 95Mbps card? or it ends recording when reach 4GB ? thanks!
@TrackZillas awesome information. the report about the 95Mbps card and the 20mm lens makes possible to work without worries!!! i-Dyanmic is working, WOW! I agree the gh2 720p is better than other cameras, to my eyes it wins over the t3i and 5n 1080p.
differences from versions uploaded day 05 and day 07 september: first thing is that the old versions e and f which did an attempt to increase the I frames size in 1080p24 was abandoned. The 1080p24 is already perfect balance between resolution and texture. second is that now the patches are tweaked to work in PAL also. now the boson are the first five patches from seta to sete and workhorse are the setf to setj. now there is 5 different datarates for 720p, the higher datarates are in seta and setf respectively for boson and workhorse, than it decreases in 5 steps from 70Mbps to 48Mbps from seta to sete in boson and from setf to setj in workhorse. I did this to make it compatible with slow cards, but the best thing to do is to get a fast card and use the boson seta or the workhorse setf.
I think if you use the boson it will be ok all the time because the SH slot priorize the noise and the H can be useful for complex detail scenes, so the H does similar results that the workhorse does with the plus of perfect noise in the SH. the workhorse is a little more stable in 720p but your reports about the 95Mbps card shows that the boson can surpass this.
waiting to see your job!
@apefos One last observation the grain structure is fine like film you can see the individual grain in the shadows with i-Dynamic turned on the (High)
@apefos What's the difference between this new updated patch and the older one?
@apefos Boson SH - 95mbs Card - Panasonic 20mm - i-Dynamic (High) Works perfectly.. I'm In love with this patch amazing job once again. The images look soo.. filmic I see why you said Alexa looking. This has to be the best 720p image out of any camera currently that I've seen & is far superior to a lot of 1080p cameras just WOW!!! By the way got a music video that I'm about to shoot this week, my line-up will be GH2 with your patch for all Slomo's and the BMPCC for all 1080p work I'll keep you posted.
workhorse boson, versions 07 september 2014, works in NTSC or PAL
highest possible careful settings for very high image quality with enough stability for short takes up to 5 - 8 minutes.
improved to deliver the best textures and fine random noise in all modes
boson:
*SH slot improved for best textures and fine random noise (this is what makes the boson very special)
*H slot has slightly less quality than SH but it is more stable
*HBR is improved for great textures and fine random noise (very special)
*24p is improved for best textures and fine random noise (just best cinema)
workhorse:
*slightly less quality in 720p SH slot, almost unoticeable, but it is more stable than the boson in 720p
*HBR has same boson settings but can be more stable also due to share some 720p settings
*same image quality of boson in 24p
from seta to sete = boson (5 versions)
the difference is: seta has the highest datarate for 720p and hbr, the 720p and hbr datarate decreases a little in each version, this is for you to find the best stable version for your camera+card+lens combo. try the seta first and change if needed.
from setf to setj = workhorse (5 versions)
the difference is: setf has the highest datarate for 720p and hbr, the 720p and hbr datarate decreases a little in each version, this is for you to find the best stable version for your camera+card+lens combo. try the setf first and change if needed.
tips: manual focus legacy lenses allows more stability. disable image stabilization and i-dynamic when using native electronic lenses for more stability or load a lower datarate version.
Tested with the Sandisk 32GB SDHC Class 10 U1 45Mbps card. Very fast cards recomended. Use TOP memory cards.
as of september 07 2014 all versions are modified flowmotion 2.02 with extensive careful tweaking
please donate to www.personal-view.com
@caveport thanks, I had a look, different approach, inspired try something different.
@apefos You might want to look at the HQ3GOP hack for PAL inspiration. It works very well on my camera and spans forever! It has a very nice fine noise & not much macroblocking in shadows. I only use 25fps, 1080p highest bitrate option with HQ3GOP.
advice for PAL shooters: boson is not tweaked yet for work in PAL, I am doing attempts on it.
@TrackZillas thats great news! I am happy I did not stop the developing!
Please, let us know if you can record in the Boson SH mode with the 95Mbps card, the Panasonic 20mm lens with the i-dynamic enabled. I would like to find the best datarate for the i-dynamic works.
Many thanks!
@apefos Just reporting back my findings on the patch.. My first impression after reviewing the 720p footage from Boson was Wow!!! it almost looks as good as 1080p I'm amazed of the quality no muddiness in low light shots. I can only imagine what daylight will look like. Tomorrow I'll do some more extensive test.. by the way I shot with the Panasonic 20mm lens with the 95mbs card with no problem cheers.
@apefos Great... This patch seems like it's the one. Charging my batteries right now waiting the flash my GH2
@TrackZillas thanks.
yes, the boson is even better in SH for 720p60, the mud in low contrast areas is gone. the noise is more fine and random, it looks like film in all the image.
there is some price to pay: the i-dynamic does not work with native lenses, it stop recording, but with manual focus lenses the i-dynamic does not stop
I did a test in good light some minutes ago, boson SH is better.
@apefos Wow!!! man better than workhorse my GH2 is back out of retirement like Jordan :) Appreciate all your hard work.
@Trackzillas Thanks.
The Boson can be used in day shoots and good light shoots at night also. It will be the same quality of workhorse for good light or even better. every texture in 720p will be better with the boson SH. problem is: the boson is not as stable as the workhorse.
@apefos Great job apefos for the longest I've been waiting for a hack that really focuses on the 720p mode, and you did just that. Going to download and give it a test drive now my BMPCC has a true friend for slowmo.. ;) Got one quick question Workhorse for Day shoots & Boson for night shoots correct? Keep-up the great work..
these patches are GOP3, not all-i. the 1080p24 is IBB, the 720p60 is IPP, I used IPP in 720p because the P frames are bigger than B frames in my tests.
I do not know if the blue channel noise is improved compared to the stock firmware... if I can remember correctly it seems to have a little less chroma noise, but to be sure It would be good idea to do a comparison.
@apefos Ah I see, that is interesting. So these are not "all-i" recording hacks? They are all IPB? Do these hacks help to reduce things like the terrible blue channel noise at high iso, or does it just make it a finer noise?
no, no, it is a different approach, see:
the datarate in the default version and in the boson version are the almost the same.
what I did was to make the P/B frames bigger in low light shoots to avoid heavy compression in these frames to preserve the noise. The I frames was reduced in size and this datarate from the I frames reduction was allocated to the P/B frames to increase them. this way the noise are more similar in the I, P and B frames, and then the magic happens, a fine random noise.
I think if you have a better datarate distribution you can have better color preservation in the shadows also, maybe more strong colors, but I think the color tone will be the same... needs comparisons...
the original flowmotion already have this fine random noise in 1080p24 but not in 720p60. the workhorse is better in 720p60 and the boson is the best, excelent in 720p60 SH slot and HBR for low light noise.
@apefos Thank you for the explanation. So essentially you are reducing the H.264 compression levels to get less/no macroblocking in the shadows and to improve the noise structure? Does this affect color rendition as well? I suppose it would.
@joethepro thanks for your words. the street shoots was done with the workhorse default. if you try the boson version you will like the noise even more for 720p60 SH and for 1080p30 HBR. in the boson the noise is even more fine and random than the workhorse in these modes.
after you find the best settings for each hack patch, all the secrets are in the GOP TABLES, they manipulate the size of the I, B, P frames and how much they will vary in size depending on image details, and consequently the ration between them. knowing how to do this makes possible to extract the best form the datarate to get what you want from the image. mainly you can have priority to sharpness and detail or to fine random noise, or an automaticaly adjust between both. for cinema a constant fine random noise is better, for advertising a sharp detailed image is better.
when tweaking the gop tables the I frames cannot have a compression ration higher than 7 because the image degrades so much. the uncompressed 720p frame is 1382400 bytes, so 200.000 is the lower limit for a goo I frame in 720p, and then the P and/or B frames are increased as much as the datarate allow, when the P and/or B frames are more big and the ration between I /PB is lower the noise becomes fine and random. this is what the boson version does for 1080p24 24H and 24L, for 1080p30 HBR, and for 720p SH
I think that the scalling matrices and deblocking matrices are important, but after you have a good matrix then the gop tables is what does the job.
these last patches I uploaded are very careful tweaked in all settings, they are a perfect base to play with gop tables and understand what they do. a good thing to do would be to map the gop tables, starting with the panasonic stock values and increasing or decreasing each number one step each time. if we map the gop tables, we will can do whatever we want with the image.
at this moment I cannot do this because I am full of other tasks, very busy...
about the GH3 I do not own it, sorry. And I think that the PTool does not support it at this moment.
