three versions: (use setg if you have proper card, it avoids all mosquito noise and texture mud in the high bitrate modes)
setg: for cards with constant write speed 36MBps and above, I frames compression = 3
seth: for cards with constant write speed 24MBps and above, I frames compression = 4
seti: for cards with constant write speed 30MBps and above, I frames compression = 3.5
The patch below is optimized for cards with a constant write speed of 24MBps or above.
The I frames have a minimal compression 4.
If you have proper card, use the setg, better quality.
