High CRI >=95 led lights
  • 312DS Special Edition, High CRI led lights
    • made specially for PV, CRI 95
    • updated and improved from usual 312DS
    • Color temperature adjustable
    • easy to see screen and adjustment
    • flags
    • sturdy construction
    Check additional details and price.
    1024DS, Special Edition, High CRI led lights
    • flags
  • 11 Replies sorted by
  • @shango
    It is special order made by actual big manufacturer mostly by request of pros who get big amount of this lights from us, for all else you can check topics and feedback for original 312DS and such.
  • Looks like a really good led.
    Can anyone that owns one of these give a bit of a review? Build quality? Mix with daylight? Green-ness?
  • Actual CRI measurement
    478 x 241 - 26K
  • @Vitaliy_Kiselev
    True, but it gives a rough idea about how much light this could output.
  • @RRRR
    Wattage is electrical characteristic, not very useful.
    312 it about 17-18Wt, 1024 around 65-70Wt.
  • Interesting. Do you know how many watts these output, @Vitaliy_Kiselev ?
  • Thanks for deal, Vitaliy. Must be superb lights.
  • I like the 50%/50% mixed mode with all bi-colour LED panels as it gives the best colour reproduction (CRI), but its a shame to only use halve the power the panel could give.
    It actually depends on panel, as such thing as 50-50% exist mostly in your mind as usually good mix require more bright warm leds (as their output per watt is lower).
    Anyway, ideal does not exist in this world.
    It is just better to shoot with best that exist (such this lights made by special order).
  • Because this is how people work. They set necessary temperature and adjust brightness after it.
    Ok, than what about letting the brightness go up to 200% in mixed mode?
  • What I don't understand: Why are they using one knob for brighness and one for colour temperatur?
  • Why lights use one knob for brighness and one for colour temperatur?
    If they were using one knob for the 3200K LEDs and on for the 5600K LEDs there would be the option of doubling the light output when using both LEDs at 100%. The actual mix-temperatur can still be displayed on the screen.
