Hey all, I shoot on a Panasonic GH2 with an Iscorama anamorph 2x lens. I seem to have an issue with rendering to a stretched format for anamorphic viewing.
For project properties I can set it to 3840x1080, but in the render options under custom templates. It won't allow me to use a custom 3840x1080 under the custom project size, for rendering under QuickTime which is the codec I always use. It changes to a random project size of 2048x1152 when I enter the values I want. I have no issues when using a squeezed format, but I'm trying to do a stretched format.
I appreciate anyones help and tips! Thanks
I'm using build 3154.
http://sourceforge.net/projects/ffdshow-tryout/files/Old%20files/old%20releases/generic%20builds/
Most of Vegas's internal renderers don't support output wider than 2048, but AVI does. Set the AVI output size to "use project settings", and then set the project size however you want. You can use the Sony YUV, Sony 10-bit YUV, or ffdshow-tryouts codecs inside of AVI. The Sony YUV AVI codecs are really just standard uncompressed YUV. ffdshow supports MPEG-2 output, and it's fast. You can use ffmpeg to remux an MPEG-2 AVI to .mpg or mp4 afterwards.
Hi, What version of Sony Vegas?Perhaps it seems like the codec has a limitation above 2k?
I think there are a few ways to deal with this but as I use a bolex with a squeeze factor of 1.5. I just type 1.5 in the pixel ratio box in the project settings and all is well. I must say I render to Cineform which has no spacial limitation. In your case you could just type 2.0 and see what happens. You can set it to full UHD with black bars or 1080 vertical. It should do the de-squeeze and fit it all in - then try a short loop render to something else like mp4 to see if it is a quicktime limitation. You could also try uncompressed YUV. Cheers
