Image quality from the Nikon D4S is among the very best in all areas. Image noise is extremely low and dynamic-range is exceptionally high.
If you're coming from an enthusiast-grade camera, and you're prepared to accept the added heft of a pro shooter with a body that could hammer in tent pegs, you'll doubtless find it to be a spectacular upgrade. The D4S pairs truly great image quality with superb performance.
http://www.imaging-resource.com/PRODS/nikon-d4s/nikon-d4sA.HTM
D4S Firmware Update C 1.10
https://nikoneurope-en.custhelp.com/app/answers/detail/a_id/61843
v1.20 firmware
http://downloadcenter.nikonimglib.com/en/download/fw/138.html
Firmware update version 1.31
Fixed an issue that occurred with WR-R10 wireless remote controller firmware version 3.00. In rare cases, the camera would fail to display the number of exposures remaining or would take about a minute to power down when the WR-R10 was connected.
http://downloadcenter.nikonimglib.com/en/download/fw/185.html
Officially discontinued
Changes from Nikon D4s “C” firmware version 1.31 to 1.32
Fixed the following issues, which would in rare cases occur when RAW+JPEG photographs were taken with write-enabled cards inserted in both the XQD and CompactFlash card slots, RAW primary - JPEG secondary selected for Secondary slot function in the SHOOTING MENU, and On selected for Network > Options > Auto send in the SETUP MENU.
- The camera would sometimes freeze on restart after users had (1) pressed the shutter-release button all the way down without first activating the standby timer and then (2) allowed the timer to expire or turned the camera off without first reactivating the timer.
- If the shutter-release button was pressed all the way down to begin shooting with the standby timer off, the first shot would sometimes neither be marked for transfer nor uploaded.
http://downloadcenter.nikonimglib.com/en/download/fw/203.html
