Capture and share your life’s most meaningful experiences with the HERO3+ Black Edition. 20% smaller and lighter than its best-selling predecessor, it delivers improved image quality and powerful new features geared for versatility and convenience. SuperView™ is a new video mode that captures the world’s most immersive wide angle perspective, while Auto Low Light mode intelligently adjusts frame rate for stunning low-light performance. Combined with 30% longer battery life, 4x faster built-in Wi-Fi and a sharper lens, the HERO3+ Black Edition is the most advanced GoPro yet.
Stunning video quality has made GoPro the world’s best-selling camera company, and the HERO3+ Black Edition continues this tradition. High-resolution, high-frame rate 1440p48, 1080p60, 960p100 and 720p120 video modes result in professional quality footage and allow for liquid-smooth slow motion playback. 4Kp15 and 2.7Kp30 enable ultra high-resolution, cinema quality capture.
GoPro is proud to introduce SuperView, a video mode that captures the world’s most immersive wide angle perspective. It allows you to capture more of yourself and your surroundings in the shot—resulting in captivating, ultra engaging footage.
Enjoy crisper, clearer footage with reduced distortion. The HERO3+ Black Edition boasts a 33% increase in image sharpness thanks to its sharper lens and 2x reduction in imaging artifacts.
The HERO3+ Black Edition features upgraded audio performance, capturing even the most subtle of sounds.
Featuring a 30% increase in battery life.
Info/direct buy at:
Available also at:
Reviews:
New tutorials
Quickguide explaining the settings of your GoPro Hero3+ camera
http://www.sauloliveira.com/index.php/en/working-material/139-quickguide-gopro
Comparison with other cameras
Yep, by including the old Hero3 update on the press release, GoPro have pissed off many Hero3 owners you thought the new features also applied to that camera...they ain't happy :-)
There is also this from the yet to be updated Hero3+ manual about Protune.
With the latest HERO3+ Black firmware update (March 6, 2014), Protune has four new controls for more flexibility.
I know there has been some concern expressed here that the need to color correct in post is too much burden for some, especially those not using Studio, but you still want the higher data rate or less-sharp image. Also, our broadcast customers often don't have time to correct before airing, but want the higher data rate too.
Now you can use the normal GoPro Color development AND still have control over sharpness and utilize the higher bitrate!
Here's the language from the updated manual:
PROTUNE SETTINGS Protune enables advanced control of White Balance, Color, ISO Limit, Sharpness and Exposure.
PRO TIP: Making adjustments to your Protune settings will not affect your non-Protune video modes. You can reset your Protune settings to their default states by selecting RESET in the Protune menu.
[list][b]White Balance[/b] - White Balance adjusts the overall color tone of videos. Standard video records in AUTO White Balance only. Advanced users can make adjustments to the White Balance settings when in Protune mode.
White Balance Setting Recommended Lighting Conditions 3000K (Default) Warm light (incandescent or sunrise/sunset lighting) 5500K Slightly cool light (cool fluorescent, average daylight) 6500K Cool light (overcast conditions) Cam RAW Industry standardized optimized color
PRO TIP: Cam RAW mode yields a minimally processed data file direct from the image sensor that allows for more precise adjustments to be made in post-production. Recording in this mode takes full advantage of the image sensor’s capabilities.
[b]Color[/b] - Color allows you to adjust the color profile of your video footage. There are two Color options: GoPro Color (default) and Flat. GoPro Color delivers the same great color you get when Protune is turned OFF. Flat results in a neutral color profile that can be color-corrected to better match footage captured with other equipment, offering more flexibility in post-production. Due to its log curve, Flat captures more details in shadows and highlights.
[b]Color Setting Resulting Color Profile[/b] GoPro Color (Default) - GoPro color-corrected profile Flat - Flat, neutral color profile
[b]ISO Limit[/b] - ISO Limit adjusts the camera’s sensitivity in low-light environments, and creates a balance between brightness and resulting image noise. A higher ISO Limit will result in brighter footage, but you may experience more noise. A lower ISO Limit will result in darker footage, but will deliver reduced noise.
ISO Limit Setting Resulting Video Quality 6400 (Default) Brighter video in low light, increased image noise 1600 Moderately bright video in low light, moderate image noise 400 Darker video in low light, reduced image noise [b] Sharpness[/b] - Sharpness controls the sharpness of your video footage. There are three Sharpness options: Low, Medium and High.
Sharpness Setting Resulting Video Quality High (Default) Ultra-sharp video Medium Moderately sharp video Low Softer video that allows for more flexibility in post-production
[b]Exposure[/b] - Exposure compensation affects the brightness of your video. Adjusting Exposure can improve image quality when shooting in environments with contrasting lighting conditions.
Exposure Settings +2.0 +1.5 +1.0 +0.5 0 (Default) -0.5 -1.0 -1.5 -2.0 [/list] Pro Tip: Exposure compensation adjusts brightness within the existing ISO Limit. If brightness has already reached the ISO Limit in a low-light environment, increasing your Exposure compensation will not have any effect.
And yes, Studio 2.0.1 supports all the new features, too.
Got it. It is from GoPro PR.
VK, you might want to note that the "All HERO3 cameras – update 3.0" was an earlier update from July 2013, there are no new updates for the Hero3 cameras only the 3+
Blog post about ProTune 2.0
HERO3+ Black Edition – update 2.0
HERO3+ Silver Edition – update 2.0
I understand that I am asking a lot for the 120 FPS mode to work in low light with such a small sensor. However, it isn't that great outdoors either.
There is such a HUGE jump in quality from 720p to 1080p on the GoPro 3 that I just wish 1080p could do 120 FPS.
Honestly, if I could get 2.7K @ 60 FPS I would probably be completely satisfied. Isn't the A9 capable of that?
There is a lot more noise on Narrow and Medium than on Wide for the 1920x1080 modes (IMHO). I don't use them. I only use full-wide at 1920x1080 24fps, Protune. That is the sweet-spot for me, along with 2.7K Cine Wide 24fps Protune.
