Atomos Shogun 4K recorder
  • 157 Replies sorted by
  • it is not a recorder
  • Forgot to mention: it is for BMPC4k
  • "The Shogun is a 7″ IPS monitor backed with recording capability. It is the only 4K HDMI recording solution that can take advantage of the A7S’s 4K signal, 120fps HD output and custom HDMI timecode with start / stop trigger.
    The Shogun also has 12G SDI ports and will record 4K ProRes onto single SSDs or RAID.
    The recorder will be priced under $2k.
    The Shogun also allows uncompressed raw Cinema DNG capture, although I believe this is over HD-SDI only.
    The release date for this recorder is not until end of Q3 / Q4 2014, so potentially GH4 and A7S owners could have a while to wait for glorious 4K over HDMI."
  • Is this about the 4k sony with 40000+ ISO?
  • It's a 4K recorder.
  • May be it is better to post at http://www.personal-view.com/talks/discussion/9859/nab-2014#Item_22
    Otherwise it can be only recorder.
  • 4k in general, or the GH4 with 4k?
