The Nikon D3300 DSLR camera is now officially announced. Here are the specs at a glance:
Info:
If this turns out to have the new Toshiba sensor in it which the D5200/D7100/D5300 have then I think this will be my next Nikon camera! But even if it doesn't, this is would still be the cheapest DSLR (so ignoring mirrorless for the moment) which does FHD 60fps.
Nikon Refurbished D3300 24.2MP Digital SLR with 18-55mm and 55-200mm VR II Lenses, $399
Coupon - 50SAVE
Nikon D3300 Firmware update v1.02
Fixed an issue that sometimes resulted in incorrect exposure for the first photo taken in live view.
http://downloadcenter.nikonimglib.com/en/download/fw/249.html
D3300 Firmware v1.01
AF-P DX NIKKOR 18–55mm f/3.5–5.6G VR and AF-P DX NIKKOR 18–55mm f/3.5–5.6G lenses are now supported. Vibration reduction can be enabled or disabled using the new Optical VR option in the photo SHOOTING MENU, which is displayed when an AF-P DX NIKKOR 18–55mm f/3.5–5.6G VR lens is attached.
The following issues have been addressed:
http://downloadcenter.nikonimglib.com/en/download/fw/174.html
D3300 offers plenty of desirable features for photographers wanting to upgrade from fixed-lens point-and-press cameras. Not only does it include many more adjustable functions, it also supports the essential P, A, S and M shooting modes and its larger sensor and 24-megapixel resolution will deliver much better image quality
http://photoreview.com.au/reviews/dslr-cameras/entry-level/nikon-d3300
If the D5200 sensor and the D3300 sensor are so similar, then why does their dynamic range scores have just over a stop difference:
Odd? Though they get kinda almost the same overall score in the end, thanks to the D3300 doing a bit better in low light.
http://www.dslrbodies.com/cameras/current-nikon-dslr-reviews/nikon-d3300-review.html
Thom now has his review up.
Like its predecessor, the D3300 is an entry DSLR camera with a 24mp Nikon-made DX sensor. A lot of folk were expecting Nikon to use the Sony 24mp sensor, or maybe the Toshiba one, but it appears that Nikon once again is using its own sensor tech.
Hmmm... appears he thinks the D3300 doesn't have the same sensor as the D5200 etc?
Anyway, it seems it doesn't really matter:
It's quite possible that there is intellectual property licensing going on between Nikon and Sony. There are a few too many commonalities amongst the three 24mp DX sensors Nikon uses for them to be a coincidence, but I don't think that's particularly important. That's because the D3300's sensor is as good as it gets for high megapixel count in the DX/APS size (at least to date as I write this). Indeed, I can’t find anything outside of possible sampling error to distinguish between all the current 24mp DX cameras, at least in basic testing. DxOMark even reports remarkably similar numbers for all these cameras, despite each seeming to use a different sensor made in a different plant by a different maker.
Against the "equivalent" current Canon Rebel, the D3300 has better dynamic range and deep shadow performance, despite having more pixels (24mp versus 18mp). So the short answer is always the same: Nikon is using great 24mp DX sensors these days, essentially state of the art for the sensor size.
Never mind, I figured it out, there's a Manual Movie setting that I had turned off. Once it's turned on you can set shutter speed and iso but not aperture. but just disengage the lens a bit (if it's a nikon d with aperture ring) and then you can manually control all three in Manual mode. Great image coming out of this camera, it's the best I've seen in a dslr and I've had the 60d, 5d3 and gh 1 through 3.
The image on the d3300 so far looks as good as I've seen on any dslr and free of moire and hardly any noise in the shadows. Only problem is there is no way to manually control iso, aperture and shutter speed in video mode. Does anyone know of any work arounds for this other than exposure lock?
Comparison with D3200 at http://www.imaging-resource.com/PRODS/nikon-d3300/nikon-d3300A.HTM#IQC
The D3300 produces good quality JPEGs, with good if not class-leading high-ISO performance. The camera's Raw files hold up well for post processing, and low ISO Raw images provide a good deal of latitude for adjusting shadow tones without a huge noise penalty. Video quality is good too, though anyone looking to take manual control over settings may find themselves perplexed and frustrated by the camera's behavior in this respect.
Noise is not overly noticeable with the D3300, at least until you move to mid-range ISO settings, such as ISO 800 or 1600. You can use ISOs as high as 25,600 with this camera, although the maximum native ISO is 12,800. Unlike some more advanced DSLRs though, you're limited to one stop ISO changes (such as going from ISO 100 to 200), rather than 1/3 stop ISO changes (such as going from ISO 100 to 125 to 160 to 200).
http://www.steves-digicams.com/camera-reviews/nikon/d3300-hd-slr/nikon-d3300-hd-slr-review.html
@QuinEtiam , I usually go with the recommendation "go with the cheaper camera body" as they depreciate the fastest. (invest the rest in glass)
Would a 50mm be your first and only lens? If so, you'd be better off getting a Nikon 35mm f/1.8 and/or a Tamron 17-50mm f/2.8
Get this with the Nikon D5200 body. And any extra money either spend on a monitor with focus peaking, or on extra glass.
This would be a very nice starting out set:
Tokina 11-16mm f/2.8
Sigma 18-35mm f/1.8 (a Tamron 17-50mm f/2.8 + Nikon 35mm f/1.8G DX would be the poor man's combination instead of this one Sigma zoom lens, and is what I'm doing myself currently)
Nikon 50mm f/1.8
Rokinon 85mm f/1.4
(plus maybe a 135mm prime or a 70-200 f/2.8 zoom, if you need something even longer)
Nikon D3300 is pretty much the same as the D3200. The sensor is basically the same as well as most of the features. The Expeed processor is where things get better. The ISO is what wins me over with this camera. This is what makes the Nikon D3300 better than the D3200.
http://www.thephoblographer.com/2014/04/04/review-nikon-d3300/
Please let me piss peacefully
Good still and video image quality in a fairly light and compact platform (at least with the kit lens), good ISO performance, a relatively speedy 5 fps continuous shooting rate and a capable autofocus system give the camera a decent performance potential for folks who are willing to go beyond just setting the mode dial to full auto and tripping the shutter
http://www.digitalcamerareview.com/default.asp?newsID=5552&review=nikon+d3300+DSLR+entry+level
choices: D3300 with 50mm 1.4 or 1.2
Or D5300 with 50mm 1.8g
The Nikon D3300 is an incremental improvement on its predecessor in terms of specification and features, but its new sensor raises the bar in terms of the image quality we've come to expect from entry level DSLRs.
The Nikon D3300 is, without doubt, capable of producing impressive images, with excellent noise performance. The new 18-55mm VR II kit lens delivers sharp results, whilst giving a more compact complete package. However, we can't help feel that it would have been worth Nikon including built in Wi-Fi to help justify the price, and make the camera stand out further from the crowd, although if the price drops over time, as it has done with previous models, then this camera could end up representing excellent value for money.
http://www.ephotozine.com/article/nikon-d3300-dslr-review-24003
I'm looking at the D3300 and an external recorder. Can anybody confirm 10bit 422 clean hdmi out?
Apparently the A6000 does it.
+1.... I agree 100%....
