Founded on youtube
Found this on Vimeo. 1080p50 All I 200mb/s
@driftwood Can you set the audio meters to stay on-screen or do they go away after 10 seconds like on the GH3?
The GH4 footage does look like, for "regular" quick pans anyway, the rolling shutter Jell-O is pretty much eliminated. You do still get some on whip pans, but definitely not as unusably wobbly as the GH2 and GH3 where the image almost breaks apart in a fugly way.
The whip pan Jell-O effect looks a lot more like pro-grade Rolling Shutter CMOS cameras used on prime-time TV shows.
Maybe the GH5 will finally have a global shutter and more advanced 4k features.
I rescind my question regarding 4k out of the micro HDMI, voldemort just wrote a post stating you can and backing off his claim you couldn't. Vintage voldy....
@driftwood Is variable frame rate mode available shooting in 4K (from 2 to 30 fps)? Thx.
great to see 50p ex mode. hows the jitters in that mode? better? really looking forward to my pre order now
So what is the maximum ISO in video mode? And do you see a large noise increase on EX mode like on the GH2. Maybe its well controlled.
Excellent info btw
@Tjabo The GH4's 200Mbps All Intra is better than the GH2's hacked max of 154Mbps (moon) and 176Mbps (Mysteron) Intra settings under the new encoder and profile, so yes - demoted to B cam!
Also someone asked about 50p EX FHD All Intra 200Mbps = confirmed - see pic
The latest version of FCPX will take the 4K 8 bit files recorded off the card without problems. You definitely require a 4K monitor else you will see picture breakup during playback on a lesser spec monitor (I was using a couple of Dell's) with anything less than a GTX 670 gfx card. Alternatively you could work in proxy mode and then link to the original 4K footage before rendering out.
Here's two pictures showing a fcpx playback screen on a Dell monitor with a Waveform view at 35% (fit) view and 100% view with a waveform under 4K representation;-
[Roughly, on the fcpx viewer display expect to see a 4K whole pic resized to around 60% of its dimensions on a Dell monitor with a rez of 2560x1440] Images below are cropped in photoshop to meet 2meg limit of p-v. (images are from cinev all -5s inc -5 NR)
Stills questions:
@mpgxsvcd I only briefly looked at stills - its still not final firmware so I wouldn't like to confirm the below stuff.
With HDR mode it appears to be 3 stills jpegs combined only from what I could test.
Preview seems to fade darker around 10 seconds, if you touch nothing it will eventually disappear on the minute mark. As Mark Baber mentioned in a previous interview with p-v its to prevent screen burn in.
I didn't get time to test RAW overlaying sorry.
From what I remember Auto ISO works for manual mode upto 6400. Didn't flash test so it could be lower with it in operation.
@kevin_kirchman Well we were monitoring everything out of the full sized HDMI Out of the YAGH thru a Engineering monitor unfortunately didn't have time to test the mini. However, I'm hoping to test out the Convergent Design Odyssey 7Q in the forthcoming days with the GH4 thru the internal miniHDMI TypeD connection as well as the YAGH. I wouldn't be surprised if someone beats me to it though.
Hi @driftwood, I noticed your pics above mention HDMI out of the YAGH for 4k display. In the Zacuto video, the panasonic rep mentions that 4k can be output via the HDMI on the actual camera without the YAGH, but voldemort says it can only do the 1080p down-convert.
Any clarification would be appreciated :)
Auto Down convert to 1080p from 10-bit 4K via hdmi.
@ghill We had it monitoring at 24p through the hdmi out, I suspect (as far as the the latest test firmware goes) all is good with 96fps thru hdmi (24p wrapper).
Found a new video up on youtube that shows both an alexa and gh4 at 1080 96fps. It's the first one I've seen where the gh4 was deliberately set to give a flat profile.
@chauncy I'm the gorilla!
Excellent cinemode comparison thank you.
The -5s are saturation, sharpness, contrast and other 2 settings which make it the flattest profile possible without baking in the camera processing.
Looking at both it's easy to say that V on the left is geared to a faster more standard work flow and looks as the name suggests videoey.
The C on the right Cinema preserves the most dynamic range possible in the camera and looks very close to a flat picture style on a Canon. Of course with real resolution advantages.
Very impressed overall with the look.
Can't thank you enough for the time spent doing these tests.
pic with driftwood and the monkey: I'm confused.
Which one is Nick and which are the monkeys? All I see is three monkeys in each picture.
what are all the -5s ?
@driftwood it would be great to have a couple of files as recorded on an SD card - one with greenscreen and one with a varying amount of handheld shaking to have a go at deshaking and see what the rolling shutter is like - if you get the chance, for those of us contemplating using this as a camera to shoot for eventual 1080.
Cine V Left v Cine D Right - -5,-5,-5,-5,-5
For those with $1699...it might be, but I still love the mojo of the GH2.
Is it safe to say that the GH4 will relegate the hacked GH2 to "B camera" status then?
@Oedipax conceivably he could be adding moblur back after stabilization with something like RSMB. Doubt it, but maybe.....
