Now that the new PTool 3.64 supports the GF2 alongside the GH2 (Vitaliy, your work is absolutely amazing!!!), it would be great to see some actual footage with any of the new patches that also work for the GF2. There is bascially nothing out there on YouTube or Vimeo.
I'd love to add a GF2 to my GH2. Any hacked sample footage would really be helpful in making that decission.
Thanks to everyone in advance for this. I am sure I am not the only one who'd love to see some tests.
recently, i set up two gf2s for shooting the concept / performance of a singer: (1) with pana 14mm 1:2.5. sandisk class 10 sdcard. (2) with oly 45mm 1:1.8 noname class 6 sdcard. (1) & (2) were each mounted on tripods. the focus was set manually with stand-ins before the actual shooting. "manual" mode: each camera kept its settings, which were set with the flicker reduction of 1/50 in mind, meaning: i adjusted iso & aperture in order to have an exposure of 1/50. of course, wb was also set manually. then, i hit the record button. it worked out pretty well having the even lighting in the closed interior setting. i'm still working with the same nice hack: driftwood's cluster v6 nebular variation; shot in 1080i, edited in kdenlive, no cc / manipulation, rendered to 720p. simple.
hi ,this a little test with Sanity V in GF2 (not used color correction, contrast, sharpness, or anything)
Ditto on the Olympus 45 f1.8 on the gf2 , perfect match for video or stills if you use the auto functions, but also awesome image. The extra sharpness of the Oly gives the gf2 a visual resolution lift.
If you want to get rid of the rolling shutter caused by global camera movement there are plenty of ways to reduce - if not even fix it. The most advanced is "Rolling Shutter" by the foundry, but there is also cheaper ways like the new rolling shutter plugin in After Effects or the correction the NewBlue Stabiliser.
If you want to get rid of the rolling shutter caused by global camera movement there are plenty of ways to reduce - if not even fix it. The most advanced is "Rolling Shutter" by the foundry, but there is also cheaper ways like the new rolling shutter plugin in After Effects or the correction inside the NewBlue Stabiliser.
thank you very much! @subco i dislike the rolling shutter too. but what you gonna do? i know that a tripod helps in stabilizing the whole video. anway, i won't change the system... i did no color grading on that. it's a nice match though, i simply trusted the cameras (iAuto). i wanted to keep it simple, make it quick, the editing process too. @AlbertZ you are one of few who says something like that. i have no old lenses, i don't want to invest in old standards. but still, there are pretty nice videos which were made with old glass! e.g. @zinin in "gf2 stable settings" thread
great video, @francofuego. I've noticed that GF2 performs much better with new lens like the Olympus 45 1.8 that using Canon FD...
@isazaly GREAT quality!
Here is another one with Flowmotion and some grading comparison:
@AlbertZ Yes. I was surprised. More crude test with Color Grading soon :)
@isazaly Great video! Better than gh1 and canon 7d!
Here is my test footage:
filmed using a hacked gf2, flowmotion 1.11 - iA, 14mm / 2.5. one shot, hand held, filmed in iAuto 1080i, scaled to 720p (which is represented in the attached files). any tips for filming concerts? in the meantime, i've switched to driftwood's cluster v6 nebular variation.
@subco yes, the screenshot shows interlaced video. how can i get more informative pictures / screenshots to upload? should i convert the video and then make a screenshot?
@kirankdwd , amazing, ND filter ?
