i assume it will cos like $800
The model is called GH4 only, and well specs are already known, only codec implementation is not defined
IMHO, 4K video at 4096×2160 pixels and max frame rate of 96fps, it's really hard to believe.
Do you have plan to sell GH4 on personal-view? I think that biggest problem will how to buy (esp. for Russia with current 200 euros limit)
LOL. Hold your horses. Btw, Russian limit is not changed yet.
@Vitaliy_Kiselev what do you think about it? I mean with these rumored specs and images?
@Vitaliy_Kiselev Do you have plan to sell GH4 on personal-view? I think that biggest problem will how to buy (esp. for Russia with current 200 euros limit)
@Vitaliy_Kiselev I see. Guess I've made a bit of confusion
It seems that P2 has nothing to do with it - http://www.personal-view.com/talks/discussion/8688/sdhc-uhs-speed-class-3-cards-for-4k#Item_6
This is all wonderful, but I doubt new Panasonic cards will be cheaper than these http://www.bhphotovideo.com/c/search?N=0&Ntt=microP2+UHS-II+Memory+Card&InitialSearch=yes&sts=ma&Top+Nav-Search=
Eyecup is slightly different and the mode dial seems a bit taller...
Edit: a button inside the control dial
Hope the 4K and 96fps is true!
I strongly doubt the digifotopro.nl sketch is the GH4K, as it looks too small, is possibly the direction the future G models are going in however?
in my opinion is that Vitaliy after a penetrate in GH3 .. maybe take out much more than offering gh4 now :-)
actually so glad the body design is the same, my GH3 battery grip and rigs will transfer right over. could see using that external interface unit mainly for tripod use...i'm sure it wouldn't be too hard to adjust my shoulder rig if for it as well. max frame rate of 96fps? really hope that's in 4K like it says. so psyched for this, would suite my work perfectly.
Is it a GH3 body? All the people who bought a 2k euro underwater housing for gh3 is kepping their fingers crossed...
In this vídeo you could clearly see that the "4K" in the camera is a sticker. :)
4K Red One files starts from 28MBps, and they are raw.
200mbps for 4K in 422 is not crap imho. Canon C 300 have a great 1080p @50Mbps :-) Ok that's 8 bit, but consider more resolution can be a little more compressed. For example a 6K at 12:1 looks good more than a 4K at 8:1. You have anyway a 18MP frame versus 8 MP. It came out after many comparison between 4k and 6K raw files. I don't post links about this, but it was vastly observed and tested.
Hope they do a nice camera, i'm into 4/3 system to my neck :-)
4k 422 10bits can fit inside 200mbps with a decent compression? We need about 100mbps to get a nice 1080p24 at 8bit. Something like a useless 422 8bits can also be expected :( Hope at least a 1080p24 turbo bit. 4k can come as addon.
Looks like a "cross-breeding" between a GH series cam on the viewers' left and a C300-style body on the viewer's right ... ;)
Neil
The second camera probably could be the rumored Leica that will be made by Panasonic...
But the bigger one...maybe the GH5 (that will appear after the G4K)? These round lines are much more "consumer" like.
That's one ugly mutha...
                  I'll wait for GH2 Mark 2 :)
Can't wait... the delusion! ;-)
@Riker This camera is apparently called 'G4K'. I assume the GH5 will be coming at Photokina.
