Specifications:
Stylus 1s
PR
Olympus announces the latest camera in the compact Stylus line, the Stylus 1s. As the successor to the Stylus 1, a camera that brought photo enthusiasts brilliant image quality and a constant aperture f2.8 lens, the Stylus 1s delivers an enhanced feature set and other improvements in a similar compact, lightweight design.
While maintaining all of the features of the Stylus 1, the Stylus 1s adds a variety of functions, such as Small AF Target, enabling pinpoint focusing on specific locations, and Step Zoom, which provides nine preset zoom positions. Olympus has enhanced the premium feel of the camera by redesigning the grip and also incorporating the blue line characteristic of the i.ZUIKO® DIGITAL lenses.
Despite its compact 2.2in (56.5mm) thickness and lightweight 14.2oz (402g) body, the Stylus 1s packs a punch with a 10.7x (28-300mm) constant aperture f2.8 i.ZUIKO DIGITAL zoom lens. This premium lens enables high shutter speeds for fast action or low light shooting environments, and captures crisp details against beautifully defocused backgrounds. Olympus anti-reflective ZERO (ZUIKO Extra-low Reflection Optical) coating, assembled through multilayer film deposition technology, is applied to the surface of the lens for incredibly clear depictive performance, even in backlit and unfavorable shooting conditions.
For close-up shooting, the Stylus 1s includes a Super Macro mode for capturing subjects as close as 5cm away from the end of the lens. With the combination of the wide converter lens, WCON-08X, and tele conversion lens, TCON-17X, it's possible to shoot from an ultra-wide-angle 22.4mm to a super telephoto 510mm. The bundled BLS-50 lithium-ion battery, which is also compatible with the Stylus 1, features an improved capacity for longer shooting times.
The Stylus 1s has a built-in 1.44-million-dot, high-resolution interactive LCD electronic viewfinder (EVF) with a 100-percent field of view that outperforms field coverage of entry-level DSLR cameras, allowing users to preview the exposure, color and focus peaks for clear images in any condition. The EVF's integrated eye sensor allows users to simply look into the viewfinder to automatically switch the display from the rear monitor to the viewfinder. Adaptive Brightness Technology raises the backlight brightness when shooting in bright outdoor conditions and lowers the brightness in dark indoor conditions, reducing visual errors from light and dark adaptation of the eye.
The Stylus 1s inherits an ideal blend of dedicated physical controls from the Olympus OM-D line for shooting professional quality images with ease. The Hybrid Control Ring allows users to quickly adjust settings with a simple twist of the ring without taking their eye off the subject. The subdial can be controlled with the thumb on the right hand, and functions can be assigned in the same way as the Hybrid Control Ring, making it easy to apply complex adjustments. The customizable zoom lever and two function buttons further improve shooting ease and speed.
Built-in Wi-Fi is a breeze to set up. Simply tap the Wi-Fi icon and launch the Olympus Image Share (OI.Share®) smartphone app to connect. By using the smartphone as a remote control, the Live View screen can be viewed on a smartphone while remote shooting in P, A, S, M, and iAUTO modes, and zoom and Touch AF Shutter are available to compose and capture the shot. Recorded images may be instantly transferred to a smartphone or tablet, ideal for sharing images on social networks.
Several new features found on the Stylus 1s are also available on the Stylus 1 through a firmware update. These features include Small Target AF, Focus Peaking, Interval Shooting, Time Lapse Movie, Easy Step Zoom, and Switchable Zoom Factor Display.
U.S. Pricing and Availability
The Olympus Stylus 1s will be available in mid-April 2015 at an estimated street price of $699.99 (available in Black).
Sample
STYLUS 1 Firmware Upgrade v2.0
Oh, and I tried bitrate viewer to see what the quality was: 20Mbit/s H264. Worse than the more usual 28Mbit/s AVCHD (assuming correct exposure so your blacks don't macro block).
I own this camera and have had a basic play with it (albeit a couple of hours).
It does zebra (both highlight and blacks), histogram has a ND 4 built in, and it can take a lens filter (via attachment CL-13). Physically, it is very customisable - fair few buttons that can be reprogrammed, and has a 28-300mm constant f2.8 lens. You'd be paying through the nose to get that on m43rds!
I was hoping it would make a nice upgrade from my Lumix LX7, which it certainly is for stills (cleaner sensor, better lens). Not so much in video though. The big issues with it for video are:
there is no manual control during video. You have to be in P mode to shoot video (if you are not it drops you into P mode), and that doesn't allow you to even lock shutter (AEL isn't maintained).
you get no UI when you are in movie record. histogram, zebra, and even aperture/shutter and crosshairs/focus points go... so you basically have the square of the viewfinder and nothing else.
No 24/25p
That's with firmware 1.0, but it looks like this is a stills camera with no ability to shoot 'DSLR film' due to the inability to lock shutter during movie recording. Its rather unfortunate, because it has a ton of video friendly features, except they only work in stills mode :(
I'll be putting in a request for movie mode to at least respect the AEL so we can get the absolute minimum (constant shutter), more chance of getting it if other owners ask for it.... not that hopeful though as this camera doesn't seem to have raised a lot of interest here!
With the STYLUS 1, Olympus has delivered an upmarket bridge camera that swaps the maximum possible zoom range for better image quality and a classier handling experience. The slightly larger sensor delivers genuine noise advantages over the 1/2.3in sensors deployed in most super-zoom cameras, the 28-300mm lens, while not the longest range around, covers most situations, and by inheriting the large detailed viewfinder, tilting touch-screen and control ethos of the OMD EM5, complemented by a clickable or smooth lens ring, it feels more like using a mirrorless or DSLR camera than a typical bridge model.
The Stylus 1 is a very interesting camera to us at Imaging Resource. What led to its development? Who do you see as its target customer, and where does it fit into the market?
Olympus: We had a lot of demand from users for a bright lens combined with long tele focal lengths, not having to compromise aperture at the tele end.
Responding to your second question, there are three targets. First, a second camera for people who are already SLR users. Second, those people who had been using an SLR, back when we first launched the DSLR -- people who kind of gave up because it's heavy and they got tired of carrying those bodies and lenses. They want a lighter option, but don't want to compromise having a bright lens. Third, for people who want to travel, pack light and have an all in one camera -- they want to go with one body. Those are the three main customers.
Given the relatively small size of the camera's sensor, the review cameras turned in a good enough performance to satisfy most potential purchasers and handled most types of lighting competently. For everyday photography, the Stylus 1 provides all of the functions most photographers will want – as well as a number of 'nice to have' shooting modes like the Super-macro and 2x digital zoom options and 'fun' features like the Art Filters and Photo Story modes.
http://www.photoreview.com.au/reviews/advanced-compact-cameras/fixed-lens/olympus-stylus-1
Built to be one of the best performing compacts available in low light situations, the Stylus 1 has to contribute its success to its sensor, lens and I.S. system. The 12-Megapixel BSI CMOS imaging sensor provides the best performance possible out of a sensor this size (1/1.7-inch). Olympus's 10.7x optical zoom lens with the constant f/2.8 aperture lens captures an amazing amount of light throughout the entire 28mm-300mm equivalent focal range, which makes it easy to shoot indoors or at night; in situations that most compact cameras normally could not handle. Helping to support this large zoom lens is a mechanical lens-shift image stabilization system.
http://www.steves-digicams.com/camera-reviews/olympus/stylus-1/olympus-stylus-1-review.html
The Olympus Stylus 1 super-zoom is a successful marriage of the company's high-end XZ-2 compact and the flagship OM-D E-M1 compact system camera. A fast lens, raw file support, a reliable 35 multi-point AF system and a well implemented manual exposure mode complete with an optional live histogram.
JPEGs had very pleasing colours, excellent sharpness and good overall tonality. High ISO is also quite good for what is after all a compact camera, and with the f/2.8 lens and effective VCM image stabilisation on board, the Stylus 1 can certainly cope with most lighting environments.
http://www.photographyblog.com/reviews/olympus_stylus_1_review/
The camera records full HD video with stereo sound, and optical zoom is available. Wind noise reduction was off when recording the video below, and the camera is a little sluggish to focus when using the optical zoom during recording.
The Stylus 1 offers a high quality electronic viewfinder, a bright f/2.8 10.7x optical zoom lens, and a larger than standard 12 megapixel sensor, bringing together an enjoyable camera to use, with impressive image quality for such a compact camera. It would be difficult to get a similar amount of zoom and image quality without spending more money, as well as ending up with a much larger camera.
http://www.ephotozine.com/article/olympus-stylus-1-review-23438
Stupid test shots at - http://www.ephotozine.com/article/olympus-stylus-1-sample-photos-23447
