JPEG / libjpeg 9.1 with wide gamut support and 12bits
  • Added support for wide gamut color spaces (JFIF version 2). Improve clarity and accuracy in color conversion modules
    Extend the bit depth support to all values from 8 to 12 (BITS_IN_JSAMPLE configuration option in jmorecfg.h). jpegtran now supports N bits sample data precision with all N from 8 to 12 in a single instance.
    Enable option to use default Huffman tables for lossless compression (for hardware solution), and in this case improve lossless RGB compression with reversible color transform.
    http://www.infai.org/jpeg/
  • 1 Reply sorted by
  • very good news!!!
