Concordia, don't worry about your G2. Just use SLR lens (m42, FD, etc. with adapters) with priority instead of the kit lens. Once you do that, you will be able to have manual control over the video using the lens. My G2 is hackable, but actually you can see the result above even with not hacked one. In contrary of the most people here, I think it's much more important what you will create with your camera instead of using it as a test mouse for some high bitrate or low GOP experiments. Those experiments will never stop and also they will never reach the quality and picture of the movie productions studios; they will always give the known artificial sharp picture and that's the limit. The reason is also known - it's phisical! If they reach a picture similat to 5D MarkII's - oh, what a dream... Whatever the hack will do with the quality, seen not much except with the test software diagrams, I bet you'd never produce a motion picture for cinema theaters or something like that. At the same time, you can make something unique and valuable depending on your mind. So, the idea and the creativity is what would impress the spectators.
thx I read also the comments here maybe I didnt notice this bad news. Poor for me, but thx. By the way somebody needs a G2? ;-) forgot to ask are there some developments in the future to hack it? you said "No suggestions"
Hey I don't want to stress people because I already asked in dvxuser forum. But maybe double help is better :-) I have a problem with the hack: I have a G2 bought in May 2011 in Germany with Firmware v 1.1. I downloaded the last version of ptool then I downloaded LPowell - Fast Action 3-Frame GOP Patch version 2. I downloaded the firmware from: http://panasonic.jp/support/global/cs/dsc/download/fts/index2.html (after unzip the file of the name is: G2___V11.bin). I read that the file must named like this: G2__V11.bin. So I renamed it then I startet Ptool as an admin load the firmware, klicked the "I" button for the seetings and saved the firmware. Then I reformat my SD card (SanDisk Ultra II 16 class), recharged my battery until there is no green light on the recharger anyomore. After this I renamed the new firmware file to G2__V12.bin and copied it to the root folder of the SD card. Then I turned on the camera and pushed the play button for 5 secs and nothing happenend.
After this I tried it with 3 diffrent SD cards with diffrent classes and also tried it with renamed files like this G2___V12.bin and I also tried it with a diffrent increment number 20 instead of 10. I always recharged the battery during the testing.
Under the title of Ptool there is a hint: Available patches for G2 v1.10, maybe thats the reason? and I only found one version of the firmware in english but I bought my camera in germany. Is the firmware from this site the right one: http://panasonic.jp/support/global/cs/dsc/download/fts/index2.html
As least I want to explain my attachment: on the left side you see the hack folder on my destop. It contains the firmware file after unzip it with the 3 underlines G2___ , my renamed G2__V11, the patch from lpowel, the new firmware file G2__V12 and the tool. Yeah in the middle you see the tool and on the right side my SD card. Thats it. Maybe someone can help me :-)
--rolling shutter is defined by sensor used (and also depends on used scan mode), so you can't improve it :-) -- yes, I know that the CMOS sensors have this problem due to the fact that they use scanline mode, I was meaning that increasing the GH2 operation speed would affect also the scanning speed and probably reduce sensibly the shutter effect.. maybee I'm supposing too much?!
Yes, fresh version. Good suggestion, but this camera are new ;) Maybe there is possibility to dump the firmware? Or just to change menu language from japanese?
I confirm, camera won't start the firmware update despite version number in the file, or filename. Maybe there is same kind of protection as was in the 'unhackable' GH1 versions. Any suggestions Vitaly?
