I don't know why I haven't been able to find anyone else having this problem, but with my card, it won't show up on my mac. It just says it can't be mounted. I tried restarting (both with and without the card in and on) and I've even tried various degrees of the "partially-in" trick. No luck.
I have two macbooks, one is a 2008 and one is 2007 or maybe 06, they have pretty recent versions and all... I can't figure out what to do. I've shot a video that I'd really like to import, so is there anyway to do this without losing the card contents too?
Hi @kingmixer,
Ok- this is what you do. NOTHING is wrong with your cards whatsoever! So NO1: DON'T FORMAT ANYTHING AT ALL.
What is wrong is that your laptop doesn't accept SDXC. Is is a common issue. Newer MacBookPros accept SDXC and are super speed as well. What you have to do is make sure you are using either 10.6.4< or 10.7<
Also purchase an SDXC card reader- such as Sandisk or Lexar. (make sure its a new one- with SDXC UHS1)
If you have any issues PM me.
Thank you for the quick and comprehensive response. I'll try updating my version if it'll let me. But it won't import through the GH2?
I have a Questions Guys.. I bought a Extreme Pro 16GB ... Its rated at 95MB/s 633X... When i started recording video it kept saying card is not fast enough or something like that.. I was a pain in the ass.. It would record 20 seconds then 45, then 20, then 2 minutes.. its weird.. I have hacked my GH2.. with the Orion 4D, but people have been using those hacks with no problems.. Also how do you format the SD cards inside the camera?
@WRLEO - I believe the 64GB make of that card is the one that works the best with the GH2.
