Been looking into adding a counterweight to my cheapo Chinese shoulder mount and haven't really been able to find anything satisfactory. I live in Australia, so I am fairly limited in what I have access to; would love to pick up one of these: http://opteka.com/cbw2.aspx, but that would cost $90, which is absurd.
Not too keen on the whole DIY lead diving weight idea on account of lead being poisonous and all. Don't particularly need a V-Mount battery pack for anything.
Any ideas? Has anyone else been in a similar situation?
I bought a 15mm rail block and glued a scuba diving belt weight to it with epoxy resin. You can buy different weights if you wanted to vary the load you're carrying.
Seen that one too. I am planning on doing a bit more research on it - should be doable if I can find all the parts. Am interested in hearing about any alternatives people may have come across.
Thanks for the help, and good luck with the GH3 hacking!
Check second link.
Yep, seen that thread, none of that is readily available here in Australia. Not for less than double the RRP, anyway.
@Vitaliy_Kiselev Since when did you add a search function to PV? This is an amazing development sir!!!!! ;)
