I bought my camera in December of 2010 and have the original firmware on it still, body firmware v 1.0, and lens firmware 1.1. Do i need to install the newer firmware first, and then the hack? Or can I just do it from where I am with the original firmware?
And I learned something new too (that I need to read the FAQs more carefully)!
Fantastic! Thanks much for the confirmation @Vitaliy_Kiselev :) Appreciate the help, and all you've done.
OK, PTool just patch existing firmware. So all you need is download latest camera firmware and use it. No need to upgrade it ahead of the patching.
I have indeed searched the forum and the FAQ. I do understand that the hack is indeed replacing the firmware on the camera, it's a custom firmware, I understand. But I'm not sure if I should be starting from the newer panasonic firmware.
http://www.personal-view.com/faqs
You'll find the answer :-) Or use search function.
@zm15 you should upgrade the camera firmware, from my understanding the hacks are based off of a newer release of firmware (correct me if I'm wrong here, anyone).
