Suitable for your tripod, monopod, rig, etc
Available in our deals.
thanks @Haberdasher can u take another picture for bottom of camera plate instead of the release plate? do u have manfrotto 501/577 to test with?
@7hau Mate I hope this helps, and that you can see the threads ok. The usual 2 in the middle, but not sure about the 2 on the end which are the same, but smaller than 1/4 20. Certainly not buttery smooth, a couple of mm's between flush mount and the thread engaging. Good value for a handy base plate. cheers.
I always look at these combos to check if the Release Plate (sprung, levered, bottom) and the camera plate (screw-in, top) are sold separately. Some are, some aren't.
Personally, I have one camera and move fast between several rigs. I need:
| Item | Tops | Bottoms |
| GH2 | 1 | 0 |
| Tripod A | 0 | 1 |
| Tripod B | 0 | 1 |
| Cowboy Rig | 0 | 1 |
| Skater Dolly | 0 | 1 |
| Stabiliser | 0 | 1 |
| Monopod | 0 | 1 |
| Car rig | 0 | 1 |
| Shouldr Rig | 1 | 1 |
| TOTALS | 2 | 8 |
(Note: A whole shoulder rig can itself be mounted on a tripod to avoid taking the matte box off. This kind of rig has a camera plate at its bottom to attach to a tripod as well as a release plate on top to attach to the camera).
Is it compatible with Manfrotto 501/577 plates? It looks like it might be.
