 I actually saw the top of the camera start to stretch up.....the top of the camera was moving up while the bottom stayed nice and tight on the cage. If I had not been going slow and paying attention I'll bet I would have pulled the camera apart or broken something. I'll need to go back to the hardware store and find some kind of spacer to fit in here. Someone asked about a stack of washers on the bolt in a picture on the original Shrigg Jig post. Something in here is a MUST!!
 I actually saw the top of the camera start to stretch up.....the top of the camera was moving up while the bottom stayed nice and tight on the cage. If I had not been going slow and paying attention I'll bet I would have pulled the camera apart or broken something. I'll need to go back to the hardware store and find some kind of spacer to fit in here. Someone asked about a stack of washers on the bolt in a picture on the original Shrigg Jig post. Something in here is a MUST!!  you can see just how far back it is and it still needs to go back some more to balance. Shrigg mentioned that indiesystems makes a long plate so you can achieve balance....but you would still have to hang it off the back.
