I'm looking for this 45 degree rig elbow...but can't seem to find it under those keywords on eBay. Any idea how do people call those?
@Brian2020 That's good for people who want just one angle and may work for Riker. I need something adjustable. But hell yeah - great DIY idea for fixed angle. Thanks
If your 15mm rods are threaded inside, just go to the hardware store and get a threaded rod that matches. Bend it n a vise to the desired angle and then cut out the bend plus a 1/2 inch on either side of the bend. Easy DIY.
@Riker I think a DIY solution is doable. I'm gonna head over to hardware store and see if I can find something like an adjustable hinge type thing. I'd like to use my rig for stability and have flexibility about how high or low the camera is. If I find solution I'll post it. Please let me know if you get a solution as well
Many types of shoulder rigs have that part in the rear, it is like a pivoting locking plate that can be tilted up or down in 45 degrees increments, since it locks on an octagonal shaped something.
There is a screw on the other side of the rig in your pic that tightens the rear part in place at desired angle.
For example, I have this 'advanced rig' from PV deals:
http://www.personal-view.com/talks/discussion/810/special-deals-complete-rigs-and-rig-parts#Item_64
Is that the part?
I think search for shoulder pads and rigs. It is part of some rigs. Do not know if it is available separetely, hope so.
