So a mark/blotch has appeared on my videos recently! I think it happened after a lens change and there was some dust/dirt on the sensor as well which was visible with a loupe. However the mark in question doesn't seem to be visible when looking at the sensor?! It is present when using different lenses/no lens even It moves in ex-tele mode (to a position which would seem to correlate with the sensor crop of that mode) If I shoot a scene which has an over exposed section it will disappear as I move the camera to place the mark onto the over exposed area- i.e. no present when over exposed
I have tried a blower to remove the dust and also swabbed the sensor with a cleaning kit which removed all the dust etc. but this mark remains!!!
So what does it look like to you and has anyone encountered something similar?
Thanks in advance all!
and I assume there is nothing visible on the sensor using your eyes?
Time to get a Pocket BMcc
Sorry meant to say I have done several pixel refreshes, and used the in camera sensor clean as well as the physical cleaning I mentioned.... It is perplexing and worrying!
Looks like dirt. Since you've already tried cleaning the sensor, maybe a pixel refresh would be helpful?
