Yes I have Towi. The difference between replacing T4 with T2 as opposed to T1 is negligble, but my tests weren't exactly great, I just wanted to see if it fixed the cadence problem. I did notice some small pulsing sections with the T2 in streamparser, but it was probably down to what I was actually shooting (and I couldnt see anything noticeable hapening to the footage, but havent analysed it properly). Anyway the still scene I shot for 2 minutes did settle down into a consistent pattern, its just the switch from the first 20 odd seconds to slightly different frame sizes that is still weird. I'd like to spend more time on this but things are pretty hectic here, so I'm doing these tests while doing other things.
Vitaliy, any thoughts on the frame size changes I see after 20 seconds where B frames grow and I and P frames shrink ? I think what I'm asking really is what is the trade off for this solution ?
Edit : If you check the overall bit rates things seem to stay consistent accross the tables used, its just where the bit rate is allocated that seems to alter with each table. But I'm only guessing.
@cbrandin GH2 filtering image at 24 qp min before being decoded. it looks like a significant loss of quality. Perhaps this is a reason we do not see a drastic difference between 44 and 88 mbit . if we could reduce the value or to exclude filtering it would allow the codec to work with the original image values.
Yes it definitely helps. I've not done proper rigourous tests, I've just shot the same plant outdoors, so there is slight motion. As the cadence problem is so dramatically visible in streamparser no matter what you shoot, I figure its okay, though I will test it some more. It does seem that I frame size does drop off as it records, but the cadence itself is a lot smoother. I can't say for sure, but movement does also cause a slight drop in I frame size, but it does recover.
Replacing T4 2with T3 doesn't improve things much, T2 and T1 however does seem to remove the cadence problem, although I and P frame sizes do drop after about 20-30 seconds of recording. B Frame sizes increase however, and it remains a solid consistent pattern from 20 seconds onwards on a completely static shot. I took another indoor shot around 2 minutes long to confirm this suspicion which are the last two files attached here.
Edit : GOP 12, Frame buffers x2, 44MB on all tests.
Sorry, forgot to say, I've mostly been shooting with a GOP of 12. Also, there actually doesn't seem to be much wrong with the footage itself when I play it back, but I guess I'd notice it in post if I had time to play with it.
I'm getting the same Kron, I've tried settings at both 44 and 66MB with double and triple buffer sizes respectively. There seems to be no predictability to it either except that it will happen sometime when you've shot over a minute. I've mostly been shooting long static shots. Oddly shooting outdoors with an ND filter seems to make it less likely to happen, I'm going to just try and turn the AQ off before going back to the stock firmware.
PTool v3.62d cannot produce stable settings for me, the uneven cadence always appear at some point in the clip. I never went over 44Mb, played with buffers, AQ, GOP, or used defaults, or variations of such, but always the cadence issue. I reverted to stock firmware for now.
p.s.: I did all my test with the voigtlander 25mm and on manual mode only.
Wouldn't changing your FB sizes based on your 24H setting really knock the ratio between I frames to B and P frames badly out of whack for the 24L setting ? In that it would be a good idea to set your 24L bitrate not that far out from your 24H bitrate ?
I think Panasonic gets around some of the filtering CPU overhead by using pre-calculated tables. Those tables don't change below a QP of about 24. My guess is that they didn't bother with lower settings because they assume the QP will never go below 20 (the factory low limit). I think I know where they are, but the parameter tables have other stuff mixed in. I'll have to decipher what they are doing.
Guys, lads, girls and men..............dont you think we should have a post that is about what settings are working and what are not. Like a checklist because is it just me or is there lots going on.
If you go too low with QP the codec runs out of bandwidth before finishing a frame and the lower part looks like crap. Try it, it may be possible to go a little lower. You have to use the manual QP settings in the tester section, though.
It depends on how much you have raised the bitrate. If you have doubled the bitrate New QP = Old QP-6. If you are using 88M, for example, New QP becomes Old QP-12. If you set AQ lower than 4 the decrease in QP is proportionally less. If you set AQ to 0 it doesn't change it at all. The factory default QP is 20. The actual QP can change from frame to frame depending on the nature of detail and type of frame. Typically I frames use a QP range of QP-2 to QP+2, P frames use QP, and B frames use QP+2.
for 50i I wouldn't raise the bitrate over 32Mbits (default doubled)... lots of artefacts can happen in motion otherwise. I never understood the values suggested in PTool. The new AQ patches however DO improve IQ... 50i looks remarkably better than the stock GH2.
