Hi guys, can anyone recommend a 720 60p setting for the GH2. I have Intravenus currently installed for 1080p but need a good 720p 60p setting. I will be filming a music video in a wooded area amongst lots of trees.
Thanks for you help guys,
@thoughts2uk You might be fine with that (though you don't mention whether you mean IV 1 or IV 2).
Among the newest other settings, I typically use the Moon 5 Trial. But for sessions where I need proven reliability I will often use settings I'm more familiar with. Sedna and CM Night did well for me in the past (CM Night obviously being better for lowlight situations as it does well with detail in those situations but is slightly more prone to banding) in terms of detail and Flowmotion 2.02 is one of the most reliable settings I've tried for 720 60P that still has a GOP of 6 or lower.
My suggestion would be that if image quality in high motion is a concern, that you rule out anything with a GOP higher than 6.
Here are a lot of the older ones. http://www.personal-view.com/faqs/gh2-hack/gh2-popular-settings
@thepalalias I have 'Intravenus I' currently installed as I've been told this produces an amazing film grain and is one of the best looks straight out of the camera and holds up great in the grade. Do you think Intravenus II out performs Intravenus I? The idea of the shots is a couple just walking through the woods, so not huge amounts of movement as such, just planning to use slider and also steadicam. The steadicam will be used to film one of the artists singing as he's walking in the woods.
I have not done extensive testing of the final release versions of IV 1 vs IV 2. I can tell you that in their earlier versions used in the earlier beta-testing, I preferred the look of the Smooth Cinema matrix used in IV 2 to the 444 emulation one in IV 1.
But don't overthink it. The differences are not "huge" and both versions of IV will give you good footage.
EDIT: I suppose it might be helpful if I explained why. I found that Smooth Cinema matrix was flattering in the way it handled fine details and light contours, etc. I found that while it preserved a lot of detail, it did not sacrifice overall image quality to do so. It felt very "consistent" and "flattering", while of course maintaining high bitrates and doing well in grades.
I am looking forward to doing some testing of Moon 5 vs. IV 2 if I can find the time soon.
@thepalalias If I'm shooting at 720p 60fps should I change the shutter speed in camera to 125? will that give smoother motion than leaving it at 50fps. (I will conform it to 24fps in the edit but want the smoothest slow motion.)
@thoughts2uk Here are the basics.
360 degree shutter (where the shutter speed is equal to 1/framerate): This will give you the maximum amount of light (and motion-blur) that you can get for a given framerate without decreasing the framerate. If you are shooting at 60P, that means that a 360 degree shutter is 1/60. If your shutter is lower than this (such as 1/50) then you can't actually get 60 unique images per second. A 360 degree shutter gives what is called the "video look" in regards to motion blur.
180 degree shutter (where the shutter speed is equal to 1/(framerate*2)): This will give you a little less motion blur, requires a bit more light and yields somewhat sharper images. This gives you what is called the "film look" in regards to motion blur and there are a lot of shooters (myself included) that rely on it by default for the overwhelming majority of work we do.
For slow-motion you can also go below 180 degree shutter to get even sharper images if you want. I shoot 60P at everything from 1/125 to 1/4000. But I do not like to shoot 60P with a shutter slower than 1/120 (or 1/125 for the GH2) and would advise against it.
So, basically, 1/125 would be my starting point. If you have enough light, you might want to try a few shots with an even faster shutter to see what you like best. The shorter the shutter, the sharper the image and the less blur you get.
@thepalalias Great thanks for your help
@thepalalias Are you sure your first paragraph is right? A 360-degree shutter (1/60 in your example of shooting 60p) doesn't give the "video look", which is defined by its relative freedom from motion blur. It's just the opposite, no? If anything, it helps minimize the video look for 60p footage, although to me eyes 60p always looks like video no matter much motion blur there is.
@shaveblog It is correct. The longer the shutter is open, the more motion blur there is. Now, you may be thinking of the difference between frame-rates.
A 180 degree shutter for 24 fps (1/48) is still longer than a 360-degree shutter for 60 fps (1/60) but a 360-degree shutter for 24 fps (1/24) would be longer still. It is a mathmatical impossibility for the natural blur to function in the opposite fashion. The shutter (360 deg, 180 deg, etc.) is definied relative to the framerate and it is sometimes even used to influence timelapse settings (I find that for relatively short intervals, such as 1 minute or less, using a 180 degree shutter can help.) With longer timelapse intervals the same rules apply as above but shorter exposures are often favored (though I tennd to make sure that they are 1/8 second at a minimum for that application and often longer exposures).
