Hardly ground breaking, but interesting nonetheless.
http://www.sigmaphoto.com/news/sigma-announces-new-lenses-cpplus-2013
All three DN lenses incorporate telecentric optical designs and a linear, auto focusing motor that ensures accurate and quiet focusing for video recording. They also boast metal exteriors and a simply shaped focus ring, with varying textures to distinguish each part of the lens. In addition, DN users can choose between a black or silver finish to match their favorite equipment.
60mm F2.8 DN
Featuring the natural perspective of mid-range telephoto lenses, together with a shallow depth of field, this lens allows the photographer to capture a single part of a subject with great bokeh effects. It has an angle of view equivalent to 120mm on the Micro Four Thirds system and 90mm on the E-mount system (35mm equivalent focal length). The minimum focusing distance is 19.7 inches; the maximum magnification is 1:7.2. This lens also contains Special Low Dispersion (SLD) glass, which helps minimize axial and transverse chromatic aberration.
Available for $209 at https://www.amazon.com/Sigma-60mm-F2-8-Black-Micro/dp/B00CMRTVFE/
Sigma 19mm F2.8 DN
This high-performance, wide-angle telephoto lens has an angle of view equivalent to 38mm on the Micro Four Thirds system and 28.5mm on the E-mount system (35mm equivalent focal length). As a wide-angle lens with excellent mobility, it is ideal for studio photography, architecture and starry skies. Its minimum focusing distance is 7.9 inches and its maximum magnification is 1:7.4.
Available for $199 at https://www.amazon.com/Sigma-19mm-F2-8-Black-Micro/dp/B00BPZCYK8/
Sigma 30mm F2.8 DN
This high-performance, standard telephoto lens has an angle of view equivalent to 60mm on the Micro Four Thirds system and 45mm on the E-mount system (35mm equivalent focal length). This lens, which is perfect for casual and formal portraiture, documentary photography, travelogues and everyday shooting, includes a double-sided aspherical lens that enhances its optical performance. Its minimum focusing distance of 11.8 inches and its maximum magnification is 1:8.1.
Available for $169 at https://www.amazon.com/Sigma-30mm-F2-8-Black-Micro/dp/B00BQXL6OY/
Please try to add formatting, and photos of each lens.
Any better?
At F2.8 these are a bit slow. The 19mm and 30mm are simply repackaged from the previous version. Although, having all these lenses with 46mm thread makes it easy to exchange filters. The ones that have 37mm like the 45mm Olympus I use a step up ring. These Sigma's are nice to look at ;-)
This is probably why the older ones were so cheap on BH. I got the older version but only when they were backordered so I feel like I'm going to be waiting awhile for them to arrive.
60mm lens will cost $239, it hits the shelves in mid-May and will be available for Sony NEX E mount and Micro Four Thirds mounts. Shortest focus distance is 19.7 inches. It has 8 elements in 6 groups, 7 aperture blades
This is good lenses for practical tasks, like corporate and interviews. Sharp from F2.8, and you really do not need more. Cheap enough to have full set.
"Hands-on with the new Sigma DN lenses for Micro Four Thirds" by Mathieu Gasquet http://www.bestmirrorlesscamerareviews.com/2013/03/24/photoshow-2013-hands-on-with-the-new-sigma-dn-lenses-for-micro-four-thirds/ "...my first impressions are more than positive, especially for the 60mm".
A good review, but he mentions that Sigma said that the lenses had redesigned optics, while @John_farragut says that they are repackaged.. I doubt Sigma would say as much even if they were, but has anyone seen proof of either? I'm asking because I found a good deal on the older version 19mm but if the newer version is indeed better, I'd probably give the new one a try.
Well, I got the 19mm and so far it's living up to the hype. It's a great LITTLE lens (it's so tiny, it looks like a toy) and so far it focuses fast and seems to be pretty sharp, a lot sharper than my Nikon 20mm f2.8 when wide open. The manual focus works pretty well except when you look closely the focus "steps" as you turn the barrel meaning it's not analog. The steps are fine enough that I don't see a problem focusing on specific objects. I missed out on an auction for a 30mm but I'll probably end up getting the 30mm and 60mm eventually and I'll have to do some testing to see how they work on video shoots.
I just figured the steps would either be smaller or that it would have an analog motor. In any case, I did some video testing last night and found the lens to be pretty good. One thing I really like is that while focusing, there is almost no breathing at all. I might buy the others and stick focus gears on them just for that aspect alone.
By idea they must be same as old (optically)
That the Sigma 30mm, a $200 lens, is keeping pace with it is really amazing. Obviously it’s not really a wide aperture prime, with a maximum aperture of f/2.8, but it gives world-class resolution.
Some tests of 19mm and 30mm on NEX - http://www.lensrentals.com/blog/2012/04/nex-7-lens-imatest-resolution-comparison
I own the 19 and I must say it is very strange lens and takes some getting used to (but it is worth it). Howcome you ask?
1) At 2.8 the sharpness field has some curvature. And that means no focus and reframe, that does not work to well, what you do (on my OM-D and on many micro 4/3 cameras) is to use touch focus in combination with this lens (at 2,8). The lens will then focus on the main subject and cause some nice background blurring. Not to much of cause, but nice enough to seperate main object and background to some degree.
2) At 8 the center sharpness drops a little but the edges benefit (I shoot landscape mainly so F8 is my F64) and you get a nice crisp sharpness across the field (reframing is possible but even here it is better to avoid it and go for touchscreen autofocus).
3) I use DxO in combination with this lens. Because the Olympus system does not remove CA that well (or better not at all). DxO greatly improves the image quality of this lens. I would recommend it anyway, but for this lens it is sort of essential. Not that it is a bad lens, but the guys at DxO seem to know what they are doing with this lens, the model rocks.
4) Near focus is 25 cm's and that means that with a 19 I can do closeups......not a replacement for a true macro lens (like the Oly 60) but nice to have around.
All in all, at a price tag of 120 euro an excellent lens.
I'm trying to get my hand on a 60 as well. 120 is about as much tele as I need and if the Sigma MTF graph is any indication this lens should rock even more.
Greets, Ed,
