1.33x that isn't practical for follow-focus? I'd be much more of a mind to give a new product a shot if it gave me 1.5x with this sort of caveat, like the harder to find and expensive options that currently exist. Seems like if you're making a novelty lense and encountering resistance you'd be better off making it more novel and unique in the marketplace, not less.
Also, it's maybe more helpful in these situations to make reference to "follow focus" rather than "rack focus". When you say "rack focus" it brings to mind specialized shots that shift from way-over-there to way-over-here (or vice versa), kung fu movie zooms, etc. Not being able to "follow focus" has implications on every single shot in a motion picture with either camera or actor movement. The difference in importance between these two concepts is practically an order of magnitude.
The photo below shows the strong barrel distortion in the 1.5x squeeze attempt. For me it does not worth the effort building it. Barrel will be even bigger in 2x.
Better keep the 1.33x version which works great, It has some barrel also, but much less pronounced.
Last days since finishing the lens coating tests I was working in some attempts to increase the squeeze factor to pursue the oval bokeh. There was lots of attempts in last month pursuing this thing with the help of my current optical lab, and also trying to find a CNC optical lab to work with. Today I finished all the tests I could do.
What I found is:
In the current optical configuration I have, when the squeeze factor goes over 1.5x the barrel distortion increases to an unacceptable level. Also the bokeh shape gets not perfect oval due to the lens grinding is not perfect. Any very minor difference in lens thickness from the lens sides hurts the oval shape. To get the oval shape lens grinding must be just perfect, CNC made without any error tolerance. And the optical system would need to be redesigned to avoid the barrel distortion.
The main reason I will stop to pursue the increase of squeeze factor is the barrel distortion. My optical knowledge is not enough to correct it in a more complex optical system.
Also I cannot force the big optical labs to work for a small project. All the big labs I visited in last month did not show a willing to do the lenses for me. They just do not need my small amount of money, they are busy schedule all time making lots of money in other tasks. So to stop the machines, change tools, reconfigure them, buy some tools they do not have, spend time of their workers... many business reasons to avoid the task.
The main reason I will not pursue the increase in the squeeze factor is not the problem with optical labs. I could try harder to find a lab. I could find a money partner to do a 100 lenses grinding to make the task worth the effort for them. Or even with some help from some powerful government friends I have from the time I worked with political advertising. I will not do these things because the main reason I will stop is my optical knowledge is not enough to correct the barrel distortion in bigger squeeze factor adapter.
What I will do from now is try to keep the 1.33x adapter project alive with the help of my current optical lab and charge different prices considering the lens quality in each unit. also I can do a video with each unit assembled to show the quality, so buyers will know exactly what they will pay for.
Flares behavior depends on what coating is used. there are videos showing flares behavior for different backlight color, sun and candle. To keep the flares in the same color of the backlight source the Uncoated version must be used. But the Uncoated version generates lots of flares, other versions generate less flares or avoid them, so watch these videos is a must to perceive which version is better for you taste and needs.
1) rack focus is not possible. do do focus you need a combination of focusing taking lens and focusing the adapter, you can focus from 1 meter to infinite, but no rack focus.
2)yes, it captures a wider image. 50mm turns into 37.5mm in the horizontal, in the vertical it keeps the same 50mm angle of view.
3) yes, you can get 2560x1080 after correct the compressed ratio in post
4) widest lens in GH2 is a 35mm focal lenght. In the tests I used the nikon 35mm f1.4 AIS lens. In full frame cameras widest lens will be 70mm. It is a combination between sensor size and lens focal lenght
5)No money to mass production, I am building some units at each time. At this moment I have 7 units ready to ship. Until now I sold just 6 units.
6) there is an Album and a Channel on vimeo with 10 test videos, just search Apefoscope on vimeo
Äbout price I prefer to talk in PM message to not turn this topic into trade.
thanks
@apefos I have just bumped into this project for the first time. Congratulations on achieving great results!!! I especially liked the Pink/Violet flare coating (Vitaliy_Kiselev version). But I'm slightly confused how this anamorphic adapter works:
1) In order to rack focus, do we need to rack focus on both the lens AND the Apefoscope simultaneously? This has been one factor that has been keeping me away from anamorphics. Or will it be like LA7200 so that changing focus on the lens is enough?
2) Does Apefoscope enable to capture a wider image, or is it simply vertically condensing the image? In other words, does it mean that using a 50mm lens from the same spot we can get a 37.5mm field of view? or will it be the same 50mm field of view with anamorphic looks?
3) I want to achieve 2.35:1 aspect ratio. Will Apefoscope enable to shoot 2538:1080p on a GH1 and Gh2?
4) What is the widest lens that can be used with Apefoscope? Will it work with 12mm SLR magic for instance?
5) Will it be mass produced? How much will be its price? And where would people be able to buy it?
Thanks.
Ok, I will save these things for me. If I decide in the near future to write some kind of book or script about the Apefoscope project I can include all details. I just need to take care about just show things and not judge things, show and let the audience take their conclusions.
You know better, just do not post it all, as it looks not good.
There are lots of hidden things in human behavior, lots of things you just cannot prove, lots of things you just feel and need to be silent about, because there is no way to prove.
I mean I will go until the hell to keep the project alive. It is turning into a honor challenge instead of money dig. When someone say no to me it makes me stronger.
I really fail to understand last two posts.
If people do not want to make something, they have business reasons behind this.
No need to turn it into farce.
What do you mean?
Apefoscope project is turning into a war.
I am thinking about to try government support to open some doors people are closing to me...
I just don't know why some people are trying to run away with me:
Envy? "Don't let this guy make money."
Competition? "We just don't like an intelligent and promising person near us. It's more pleasant to make things difficult to you, it make us laugh."
Challenge? "This thing is difficult to do and we do not need this money."
Busy Schedule? "Our machines are busy and it does not worth the time to make such thing."
Small Amount? "It does not worth the effort to reconfigure the machines to make small amount of plastic pieces/lenses"
First user report with photo of the unit, de-squeezed images and the same images in original aspect, also some comments:
http://www.digitalrev.com/photo_detail?id=15378568
http://www.flickr.com/photos/mjones41/sets/72157632592370798/
Hi @fatpig About the website, it exists but just with 35mm adapter information. add complete information about the scope would be ideal and I want to do it, but it will take some time to happen because there are other tasks to do first, finish rearranging the office/workshop is the priority now. At this moment the vimeo videos and P-V topic are the main info source.
Will you have a complete website soon, containing information about the scoperama? :)
I just got some advice to sell the Apefoscope optical formula.
So if there is someone or some company interested can talk to me.
Thanks
@ahbleza thanks for the suggestion. My website will need to be redesign to include the anamorphic adapter. It will take some time. Also I will need to re-setup the mailbox there. While there is no anamorphic information in my website, people can send pm here or on vimeo.
www.apefos.com
vimeo.com/apefos
@apefos I suggest one last post (before closing topic) pointing to web site for more details and description, price and availability for what you are offering, in case people decide in future to use this approach to anamorphic shooting.
I edited my previous post about my message behavior, also:
About close the topic, I think it can be closed because the project is finished. And as it is turning into a commercial product I cannot keep talking about it here because I can't use the forum as a sales promotion. I think members can open another topic about "user discussions and opinions"
Please manifest what do you prefer:
1 - close this topic and open other for user discussion and opinion.
2 - keep this topic and users can talk here.
Ok guys
I just understood the point about the messages.
I got a pre-written message from an old friend about christmas and new year and I got upset also about the message because it was pre-written, not personal written to me. I felt I was not important and just one more to send an automatic message which probably was on a mailing list. I felt like a was robot, not a human and our old friendship was not important so much.
Sometimes we want to make things fast but suddenly we found a big error in the way we are doing. This topic also teach me so much about internet behavior.
You answered me here, where i'm saying i'm not to buy now, at 11.28, then i have another email from you at 11.42. Are you so lazy to not clean from your list the people you already made the point yet? Come on man, that's people that have one single email address for business, please have a little respect.
He got my PM, next attempt will be last one.
@apefos Seriously, you have somekind of problem. I especially said for you 2-3 times that do not send spam to me, and now you did it again!
Happy New Year
no problem if you do not want to buy. Its fine.
I need to say I just sent one more message about the project end, and some units ready to ship. From now no more private messages. I also asked in the message for people do not reply in the message to avoid spam.
The project is finished and successful.
I think this topic can be closed after @endotoxic show us the logo. So the buyers can open another topic for "user discussion and opinions"
Hello Apefos, Thanks for your emails and messages, i'm happy to see you have reached your goal making these anamorphic. I'm not buying right now, but i wish pu good luck with the sales and a Happy New Year!
