We were getting stops in recording and also unable to play back video in camera with FlowMotion using SDXC 95MB/s cards. We've tried everything to the exact steps to go back re-install the latest Factory Firmware and all we (both) keep getting is "No Valid Picture" instead of "Version Up?" Any advice please? Thx, Ted. tvardalos[at]gmail[dot]com
All instructions are in
Sorry to hear you're having difficulty with hacking your camera. To revert back to stock settings, you need to use PTool 3.65d to create a patch that has only the Version Increment option checked at the top of the PTool window. All other PTool options should be left unchecked. For my testing purposes, I've saved a copy of this stock patch as GH2__V00.bin. After saving it to your hard disk, copy the stock firmware patch to the root folder of an SD card, and you should be able to use it with the camera's Version Up feature.
