Check this Ultrasharp deal (it is factory calibrated monitor)
@Vitaliy_Kiselev Great find! I'll look into it... Could be really nice as a set-monitor too. :)
This video is a good example of what I hear color correction pros says (Alexis van Hurkman wrote "The Color Correction Handbook"). He mentions that when grading for the web, a calibrated computer display is perfect, but for broadcast "you need to have a broadcast monitor". The part of the video starts at 1:00:36, which should link to directly with this link (though it won't I see):
Let me say this. Grading and choosing monitor is not religion based. It is based on simple logic and principles. And his statement is mostly not based on logic (exn expample that follow is just bullshit mostly). History of "you need broadcast monitor" goes way back. In the time than cheap, big, good and even calibrated on factory IPS based monitors existed only in dreams.
Check this Ultrasharp deal (it is factory calibrated monitor) http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=soho&cs=ussoho1&sku=320-8277&dgc=BF&cid=7420&lid=197374
I had it and I was quite dissapointed. I dont know what you get "factory calibrated" but as I experienced color custom mode of this monitor is crap. You need this mode because in this mode RGB gain sliders are available and you can adjust your illuminant white with on-board settings. See a review in German here and see how big the divergence of delta E in the green channel is http://www.prad.de/new/monitore/test/2010/test-dell-u2410-teil8.html I sold this monitor and bought the U2711
I'd highly recommend to go for the U2711 or spend some morr bucks for the NEC PA241W
I got it from monitor page.
It is 2010 year review. I have big doubts that despite same name it is exactly same monitor (as panles change quite frequently). Even 27" and 30" monitors use different panels. Plus few years ago I did check on few our local monitor reviews and measurements, most where highly inaccurate.
I also did not get slightly about your comments about crap. Did you have calibrator? As normally after switching to proper color mode, sRGB in this case, all you need to touch on monitor is only backlight strength.
LUT is defined by calibration app, so it is no different from graphic card.
The point is that you need a graphic cards with a different LUT for each different output, plus a driver supporting that feature, if you wanna work in a dual monitor environment with one monitor just for the graded preview.
So forget consumer cards and pro cards don't cost far less then a MXO2 mini.
It is also have same 8 bit output, most probably dithered
10bit 4:2:2
Right now it is zero problems to install even three cards. As even many cheap MBs allow it.
I'll check modern situation with dual LUT cards and let you know.
Added: After quick look normal cards have double LUTs.
http://nvidia.custhelp.com/app/answers/detail/a_id/77
In fact, if you are getting 27" or even 30" monitors, just get two monitors with sequental numbers, it will be enough, will work from single LUT.
10bit 4:2:2
Can you show me this part in manual and that do you mean here?
As very few monitors will accept 10bit signal, and you reall need RGB or 444 YCC.
It's a 2010 monitor. The review appeared after introcuction of the Monitor. I bought mine in mid of 2011 and sold it in beginning of 2012. I do not know exactly but I doubt that Dell has changed this monitor in the meanwhile. I calibrated the monitor with x-rite DT94. Or at least I tried to beause I failed. It was no problem with U2711. I think it's not the problem of the panel but with electronics.
Some calibrators can fail with wide gamut monitors.
As for panel - Dell can't do anything, if LG is stopping producing some panel and replace it with slightly different one, it'll be different results. Even slight change of lamps (or leds) in backlight can add difference.
From everything I have seen, IPS panel don't have a very high static contrast ratio as LCD screen in general. After a lot of research I see myself buying a blackmagic intensity pro with a plasma TV and a calibration system like calman. Panasonic plasma TV have very good reviews and are being used in post house. Unfortunately I only have old models (very expensive) or the very basic ones in my country. So I will go for this LG model
http://reviews.plasmatvbuyingguide.com/lg-plasma-tv/lg-55pa6500.html
http://www.avsforum.com/t/1390332/lg-50pa6500-and-lg-60pa6500-plasmas
Modern Alpha IPS (or latest S-IPS from LG) panels have good contrast, not astonishing, but enough.
As for plasma. It has more issues than solutions.
First, afterglow still happens, especially if you have similar things on same places (like titles in news).
Second, color gradations rendering is quite specific, with modern panels it is not big issue, but you must always know it.
Third, brightness is not the same on different situations, If all scene is bright, overall brightness will go down.
DT-94 works perfect with Dell u2711 and Quato Excellence.
http://www.matrox.com/video/en/products/mxo2/monitoring/
Added: After quick look normal cards have double LUTs. http://nvidia.custhelp.com/app/answers/detail/a_id/77
My "colleagues" under win7 (I'm a photoshop pro) have had really hard times with windows color control panel. It looks like only the profile for the main monitor is used by color-managed applications, so only pro video cards managing multiple profiles via their own drivers and utilities are a reliable solution.
I think we'll need to look more carefully on calibrating dual monitors. May be make separate topic.
As for Matrox, RGB mode is 8 bit, and 10 bit(plus 422 only) have no use with most monitors as I understand.
Nexus 4 phone have almost perfect sRGB
Jiayu G3 cheap chinese phone with 1280x720 IPS screen
Have a look at the BMD Mini Monitor ($145) 10 bit HDMI and 10 bit HD-SDI, suppports FCP, AVID, Premier and After Effects. Makes the LUT Tables irrelevant, which is the way it should be.
An apology ... When i was in PC, It used to annoy me the way Mac people forgot that some of us were on PC. Now i am on Macs, I just did ... This is a thunderbolt device.
Another portable monitoring option with good color accuracy - Dell Venue Pro 11
http://www.ebay.com/sch/iPads-Tablets-eBook-Readers-/171485/i.html?_from=R40&_nkw=dell+venue+11+pro
Any recommendations for a good (in value) grading monitor somewhere around 1000 dollars? I'm tired with my HP Z24x Dreamcolor. Massive light leaks and green cast that I can't deal with.
Try Dell UP2716D.
Nec monitors are very very good and can be had for a song sometimes...
http://www.bhphotovideo.com/c/product/801273144-USE/nec_pa272w_bk_27_led_backlit.html
http://www.necdisplay.com/p/desktop-monitors/ea275uhd-bk-sv
P series are tops E series are good but maybe not as intensely accurate
