NAMM 2013 topic
    NAMM 2013
    January 24-27 Anahaim California USA,
    http://www.namm.org/thenammshow/2013
    Let me know if you want to help us with coverage. Or just will be at the show. Send me PM.
  • 57 Replies sorted by
  • I know there's a few of us in LA that would lend a hand for the Anaheim show.
  • I made it now NAMM only topic. It'll be now some leaks, preannouncments, etc.
  • Upcoming Casio synth
    631 x 502 - 36K
  • Studio-Capture USB 2.0 audio interface with 12 mic preamps
  • Roland V-Combo VR-09 keyboard
  • Moog Sub Phatty
  • Portable RD-64 Digital Piano
  • Teaser site for Kawai Virtual Piano Controller
    http://www.kawaivpc.com/
  • Korg Mini MS-20
    952 x 960 - 228K
  • TC Helicon VoiceLive Touch 2
    With a completely reworked user interface, real-time control and new effects, the VoiceLive Touch 2 provides a complete suite of vocal effects, including Harmony.
    Its new Touch Matrix interface with Slider FX allows precise real-time control and modulation, and the VLOOP Performance Looper adds loop-specific effects to the mix.
    VoiceLive Touch 2 automatically takes care of vocal tone with adaptive EQ, compression, de-essing and gating.
    Features:
    • 9 button Touch Matrix for editing and control
    • Slider FX for hands-on experimentation
    • Hit button switches multiple effects!
    • Six-track vocal looper with midi sync and realtime loop-specific FX
    • Dedicated tap tempo button matches Delay and Rhythmic effects timing to live beats
    • Tone feature includes Adaptive EQ, Compression, Gating and De-essing
    • Harmonies and pitch correction via Auto Key Detection
    • Effects customizing with styles and icons
    • Library of song and artist presets
    • Optional 3-button footswitch allows hands-free control
    • Reverb, modulation effects and tuner for guitar input
    • Mic stand-to-desktop non-skid chassis
    • Built-in mic pre-amp
    • USB for audio recording and playback, preset backup and more
    • Mic Control compatible
    • µMod – creates flanger, detune, chorus and pitch dive effects
    • Delay – tempo-based or timed echoes, slap, and extensive filter styles selection
    • Reverbs
    • Harmony – up to 4 backup singers arranged by your guitar, keyboard or bed track
    • Choir – recreates the buzz of a large singing group, can be combined with Harmony
    • Double – a solo or group of unison singers to fatten and widen your melodies
    • Transducer – simulates radios, megaphones and distortion effects
    • Rhythm – tempo effect that creates chopper, panning and modern stutter effects
    • HardTune – Auto tuning, pitch and gender
    VoiceLive Touch 2 will be available late march 2013, price retails at $599.99 / €599
    http://www.tc-helicon.com/voicelive-touch-2/
  • Base
    Introducing Base: a new foundation for all your creative productions. Combining the technology of drum machines and touch screens, Base merges pressure sensitive pads with touch faders, all brilliantly lit with full-color LEDs. The Base inspires beats, new melodies, instant sound tweaks, and invites control of just about anything that supports MIDI. Designed in an ultra sleek, high-quality aluminum body with no moving parts, it's the ultimate mix of ruggedness and portability.
    Adaptable
    Base puts your fingers in the mix with 32 pressure and velocity sensitive pads, eight function buttons, nine capacitive touch faders, and eight capacitive touch buttons. Full RGB backlighting keeps you connected to your set and focused on control. An LED character display shows which of the ten presets you're using. Creative coders will be pleased to discover the characters are MIDI-controllable, too! The Base editor web application allows you to customize all its settings for your favorite DAW, VST, plugin, or application.
    Designed to Travel
    No sliders to bend, no knobs to catch: under two pounds, less than an inch thick and a face that's probably smaller than your laptop (10.25"x11"x0.75".), Base goes in and out of your bag from studio to show. A single USB cable powers the device with RGB back lights bright enough to see in daylight.
    Built to Last
    Base is proudly engineered, and assembled in Livid's very own manufacturing facility in Austin, TX. Solid extruded aluminum, tight tolerances, and the assembler's signature with every product, you can have confidence in Livid's latest controller.
    At Your Fingertips
    With just enough controls to fill your hands, Base keeps you focused on playing your set. Velocity-sensitive pads give you expressive control for playing and pressure sensitive pads offer unique control of your effects. Low-profile pads sit in line with a soft rubber faceplate, allowing your fingers to glide over the buttons with ease, mixing the tactile feel of a real controller, and the unique possibilities of a touch screen. Touch-sensitive sliders can be used like a regular fader, but have the advantage of instant access to any value. The touch sliders also output a note when touched, which can be mapped to turn effects on and off only when the slider is active.
    Compatibility
    Base is designed as an instrument to work with any software that supports MIDI. Whether creating beats or mixing visuals, our library of applications and presets is ever-growing. Base has some of the most sophisticated scripts available for Ableton Live, Max/MSP, Traktor, and more.
    Pricing and Availability
    Shipping March 1st, Base has a street price of $399 and is available for pre-order from lividinstruments.com and dealers worldwide.
    http://lividinstruments.com/hardware_base.php
  • Akai MPX8 SD Sample Pad Controller
    MPX8 is one of Akai Professional’s most innovative pad instruments yet. Using a standard SD card, users can load virtually any sample onto MPX8 and then assign it to any of the unit’s eight backlit velocity- and pressure-sensitive pads. MPX8 also comes with a large library of standard samples built in, which can be used for live performance in front of a crowd, on a radio show, or for in-studio production.
    Its bright blue backlit display and intuitive interface make for easy operation in any amount of light. A 1/8-inch headphone output, two balanced 1/4-inch outputs, and five-pin MIDI and USB MIDI inputs and outputs are onboard. “With MPX8, we’re giving musicians a quick and convenient way to have one-touch access to a virtually unlimited number of sounds, shots, stabs, and drops,” said Dan Gill, Akai Professional Product Manager.
    MPX8 comes with a drag-and-drop sample editor for Mac and PC for easy sample conversion. Users can also save sample sets together as kits for easy recall and even tune and add reverb to samples
    Features:
    • Add sound samples via standard SD card (sold separately)
    • 8 velocity-sensitive and pressure-sensitive pads
    • Drag-and-drop sample editor for Mac and PC included
    • Built-in library of popular sounds, samples, and bumps
    • Tune, add reverb, save sample sets for easy recall
    • USB MIDI plus standard MIDI inputs and outputs
    • 1/8” headphone output and balanced 1/4” outputs
    http://www.inmusicbrands.com/wnamm2013/akaipro
  • Sonivox Vocalizer Pro Vocal Production Synthesizer
    Vocalizer Pro brings a harmonic/melodic voice to any audio input, thus vocalizing the sound. Simply singing or speaking--or any type of vocalizing--can intuitively create deep and complex musical results. The patented technology delivers unparalleled signal processing, advanced vocoding, and powerful re-synthesis. In addition, Vocalizer Pro allows the creation of simple or complex vocal harmonies that can extend far beyond the natural limitations of the voice. Vocalizer Pro is excellent for processing any type of percussive or melodic audio track. One preset has the ability of producing thousands of different results. This is because Vocalizer Pro is not just for vocals.
    Features:
    • Revolutionary MIDI-controlled audio effect
    • Unparalleled vocoding, re-synthesis and signal processing from subtle to mind-blowing
    • Expanded controls including FFT audio processing suite
    • Pitch shift, formant, improved frequency control and spreading
    • Two rows of performance pads extend playability and live performance control
    • Standalone, AU, VST, and RTAS
    • 32 and 64-bit
  • Axiom AIR MIDI controllers
    61 keys
    • 61 TruTouch® semi-weighted piano-style keys with aftertouch
    • 12 trigger pads respond to pressure and velocity
    • Roll button aids in creating realistic drum parts
    • Assignable controls offer front-panel programming:
    • 8 rotary encoder knobs; 9 long-throw 70mm faders; 9 buttons
    • 3 banks of pad and controller assignments with color-coded illumination
    • HyperControl automatically maps controllers to popular software
    • Drum Pad Learn feature and Identify button
    • Dedicated transport and navigation buttons make recording easy
    • Octave/Transpose buttons access the entire note range, in any key
    • Assignable pitch bend and modulation performance wheels
    • Selectable velocity curves to match any playing style
    • 128 memory locations for saving custom settings
    • Functional design provides backlit LCD plus under-keyboard cable routing
    • Includes AVID Pro Tools® Express and Ignite™ by AIR
    49 keys
    • 49 expressive synth-action keys with aftertouch
    25 keys
    • 25 expressive synth-action keys with aftertouch
    • 16 great-feeling trigger pads respond to pressure and velocity
    • 8 rotary encoder knobs plus 1 long-throw 70mm fader
    • 3 banks of pad and knob assignments with color-coded illumination
  • Back to Roland V-Combo
  • Cool $99 wireless stuff, with accelerometer. May be plug it to the color grading :-)
