Crusade on MJPEG hacks
  • This discussion was created from comments split from: 100Mbps GH2 Low Light MJPEG 1080p Patch.
  • 73 Replies sorted by
  • That's not quite right. Depending on matrices, the effective QP can be much lower (lower is better). Going lower than 5 is a waste (because that's for 10-bit, not 8-bit). The new "soft" matrices produce an Effective QP of 5 (for DC value) in many cases, which is ideal, when the PTool quantization parameter is set to 18. Other settings can achieve this too. You can determine the minimum effective QP value by using the JM-SP decoder in StreamParser. The DC value is the lowest effective QP value for each frame. Basically, the quantization parameters by themselves are meaningless because they are processed with matrices to get the final, effective QP - which is what is important.
  • According to cbrandin's recent investigations, the AVCHD encoder's highest quality quantization factors used for shadow detail are around 18-20.
    Is this information still accurate? Is there any thing that limits the IQ that can be achieved by low luminance regions (putting noise aside).
  • Sorry, no resolution chart but my CD-Collection. Stills were exported using mpegstreamclip. In the AVCHD Stills, Gamma was raised for better comparison. I guess, if I used the soft SLR-Magic 0,95 instead of the 14-140 lens kit for the "sharpness test", the difference in sharpness would be unnoticable. Not noticable in the stills but more noticable in the moving image: Lesser "mudding" in dark areas (I hope it is the right term) and lesser banding with MJPEG, I guess because of more noise? A sharper MJPEG with spanning (recording stops after 2:47mins/1.99gb on Sandisk SDXC Extreme Pro/64gb) and with better audio (seems to be restricted to PCM with 16kHz sampling frequency) MJPEG would be heaven to my eye. All the best, Frame
    1920 x 1080 - 2M
    1920 x 1080 - 1M
    1920 x 1080 - 877K
    1920 x 1080 - 834K
  • @WeBcYtE>If you are shooting video and care for quality, sticking with any of the AVCHD video modes would serve you better than the tweaked MJPEG modes.
    Not so the GH1:-)
  • I tend to agree with EOSHD's earlier points. I haven't touched the MJPEG video modes since I bought my GH2. It's largely a "toy" codec that finds its way into low-performance electronics that wanted to add "hd video capture" as a bullet point on the package. The GH2 is a prosumer camera, so yeah it has some consumer-grade elements on there but it makes little sense to use them when there are superior AVCHD modes available.
    If you want to send mom a video of your pet turtle riding a unicycle...MJPEG all the way....but did you really spend $2K+ on the GH2, lenses and support equipment just to record glorified webcam-quality video? If you are shooting video and care for quality, sticking with any of the AVCHD video modes would serve you better than the tweaked MJPEG modes. I should point out that AVCHD at AQ2 with 66 or 132m bitrates does well in low light motion and shadows...and that is something that has been tested by other members on here already.
  • It's about Avchdism against Mjpegism and their repective video worshippers & -deities...
    Vitaliy spoke already about a crusade!
  • @All
    Wow. Just walked into this room. Is it hot in here or what?
  • >"The first time I tried it with the first PTools release it looked like upscaled VGA and now when I put it to 1440x1080 for example it actually looks pretty damned close to 1440x1080."
    with that sort of resolution difference, it should be quite obvious to see if VGA is upscaled. Could someone post some snapshots from a 1440x1080 MJPEG video ?
  • @Vincent. We will have a chance to do just that (or close to that) this weekend. In production this week with cameras tied up. I could try to find the couple of A/B tests I did with AVCHD and MJPEG at 1920/1080 but you're right, a res test would be best.
  • Because debating is more fun?
  • "The first time I tried it with the first PTools release it looked like upscaled VGA and now when I put it to 1440x1080 for example it actually looks pretty damned close to 1440x1080."
    So has something changed/ been improved in 4:3 MJPEG mode from the 1st PTools to the current version? If so this is great news!
  • cosimo_bullo: Matt says he sees more details than 720p, but "not much though", and to come to that conclusion he says he downscaled a SCREENSHOT from a 1080P MJPEG video to 720P then upscaled said screenshot to 1080P... I'm sorry, but what the heck does that prove?
    My question was and still is, why doesn't somebody on EITHER SIDE of this debate actually do a real test using a resolution chart shooting natively in both modes?
    Vincent
  • Hopefully we see improvements in mjpeg anamorphic setting, too.
    Who knows? One day 2544x1080 mjpeg in GH3vk or GH4vk... drooling...
  • To convert me from disliking/never using MJPEG to now actually using it for production/real world acquisition, I'd say the new 1080p MJPEG/GH2 is a very significant improvement. Well done all those responsible.
  • It seems with the latest PTools that MJPEG quality is better than before especially in 4:3 mode. My main point was that MJPEG was not a low light killer. What I do find interesting is how Vitaliy has got the better quality out of 4:3. The first time I tried it with the first PTools release it looked like upscaled VGA and now when I put it to 1440x1080 for example it actually looks pretty damned close to 1440x1080.
    Yes the 1920x1080 detail is not quite 1080p but it is an improvement. Thanks Vitaliy.
  • "So emotional. Who's attacking MJPEG or the hack? I am fucking sick and tired of you guys blowing stuff up into a shit storm. If you can't be rational then go somewhere else."
    Hello...My name is Pot...and you are a black Kettle...
    This acrimonious debate is very distracting...and pointless. If everyone had the same opinion on everything it would be pretty boring indeed.
    I use AVCHD about 99 percent of the time. Along comes a new patch for a new camera (for me anyway) which greatly improves how MJPEG looks. Surely it's up to each user to decide on the advantages and disadvantages (as personally perceived) and use the codec/bitrate/camera he thinks best for the situation.
    For example, as far as I'm concerned AVCHD in the GH2 is currently unusable FOR WHAT I DO because of the start-up glitch. 100mbps MJPEG (and particularly 30p) is very usable FOR WHAT I DO ...end of fucking drama...FOR ME.
  • @Vincent: Take a look at Matt's last comment.
  • Re: whether or not the LPowell 1080P MJPEG patch is "upscaled 720P" or not- couldn't some tests be done with resolution charts to figure that out once and for all?
    Vincent
  • > I'd be very interested to hear more tricks that can be done to fool the AVCHD into providing more detail in low light.
    We must understand AVCHD encoder better to do this.
  • From my personal perspective it would seem that the AVCHD path has more life to it. I'd be more interested in seeing how far that it can be improved upon. It looks to me to be starting from a better quality position and that's very important to me.
    Perhaps from my novice eyes the MJPEG seems to be about a stop brighter to me than the AVCHD clips EOSHD provided. Overall tho I didn't like the noise as much on the MJPEG clips. I'd be very interested to hear more tricks that can be done to fool the AVCHD into providing more detail in low light.
  • Knee grows please!!!!!!
    ...in the words of the (in)famous Rodney-the-King..."Can't we all just get along?" :-)
    Read your own posts, Andrew. You have been attaching, and in a most unpleasant way. If you're ready to get constructive, welcome back.
  • a lot of work........
  • I hear you @LPowell
    At least 480p MJPEG seems much improved with the latest PTools. Before (with previous release) it looked like VGA mode simply upscaled. Now it looks like the actual scaling resolution 1:1. What has been changed to enable this Vitaliy?
  • LPowell, I experimented with one of your GH2 1080p MJPEG clips, and there is indeed more detail than 720p can resolve. I came to this conclusion by downscaling a screenshot of 1080p MJPEG to 720p, and upscaling it back to 1080p. Comparing the before and after, it's clear that there IS more detail and fidelity (not much, though), and the picture seems smoother (less aliasing) to me. But, the camera can't be just simply upscaling the 720p image as there wouldn't be any extra detail, whereas there actually is.
