Samyang XEEN Carbon Fibre Cinema Prime Lenses
    The Samyang CF Cine Prime full-frame lens range will feature 16mm, 24mm, 35mm, 50mm and 85mm optics.
    http://xeenglobal.com/en/
    744 x 617 - 54K
  • 5 Replies sorted by
    • Full-Frame/Large Format sensor coverage
    • Lightweight construction, featuring Carbon Fibre
    • Advanced Optical Design (same as XEEN)
    • Luminous focus markings
    • 11-blade aperture for beautiful bokeh
    • Total of 5 Cine Primes
      • XEEN CF 16mm T2.6
      • XEEN CF 24mm T1.5
      • XEEN CF 35mm T1.5
      • XEEN CF 50mm T1.5
      • XEEN CF 85mm T1.5
    • Available in PL, Canon EF, Sony E mount
    • Weight about 2.1 lbs.
    • Price: TBD
    • Available: Q4 2019, Q1 2020
  • New pair added to the team - Xeen 16mm T2.6 and 35mm T1.5
    • Bright T/1.5 and T/2.6 apertures for low-light filming & control over the feeling of depth.
    • Dual left and right side scales
    • Compatible with large image sensors (43.3mm image circle).
    • X-Coating provides distinctive look, controls reflection & produces dramatic images.
    • 11 aperture blades create beautiful, circular bokeh.
    • Carbon Fibre in lens barrel delivers lightweight and durability.
    • Standard 95mm front size is fully compatible with matte boxes.
    • XEEN X-Coating controls internal reflection
    • Available in PL, Canon EF and Sony E mount.
    • Luminous paint used for model and distance markings allows effortless use, even in extremely low-light environments
    • Focus and aperture ring locations uniform across all models, with improved gear design and weighting for smooth rotation.
    • Consistent 200-degree wide-angle of rotation enables fine focus adjustment.
    • Bidirectional scale on both sides of the lens body enables easy verification & operation.
    • Detailed information about all XEEN CF and other Samyang products and stockists can be found on the Intro2020 website.
    • Covered by an industry exclusive three year warranty
    • Both lenses have an SRP of £1666.66 plus VAT (or £1999.99 including VAT).
    • US pricing will be $2495 US for each lens
    • Available in April
