@driftwood Thanks, buddy. Here's the video - details on settings are on the vimeo page.
@shian Those pictures look superb. :-)
Video coming soon - Intravenus 24H, ISO1250, Smooth -2 across the board.
                  @driftwood So much waiting for the release of Valkyrie Cinema Smooth !
@driftwood any news abt the top notch cinema smooth matrix??
Will do. Your work is much appreciated.
Primarily for documentary making this setting is very good. Its far away from Boom! Try it first and see. It needs testing. :-)
@driftwood Thanks for new GH3 Matrix test setting. What are the expected benefits/imaging differences and characteristics. (I'm thinking relative to Boom). Thank you. How's your film coming along?
*** NEW *** Quantum GH3 Matrix Test Setting for the GH2
Low mem cost - Great quality 1080p24/25p/30p Intra utilising the new GH3 4x4 matrix scaling tables & deblocking simply inserted into the GH2. Plus 3 GOP PAL 50p and 6 GOP 60p 720 modes. cbrandin's AQ1 and AQ2 is back in use here providing avg 14-16 Q for 1080 modes and lower for 720p modes. Experimental Setting requires testing.
                  a little short i shot the other day. Canis PM
Reminds me of why Sedna is SO nice.
boom is hot! sharpens up the old screw mounts nicely. heres a screen grab from something im working on. no grade. no color
                  @sanzadez.. I usually copy my footage to hard drive first but while testing different patches, I tried playing them from card directly. It both cases, it stutters. If I apply Magic Bullet on my clips, then I forget about any sorta playback (a frame or two in 15 secs) regardless of clips being on HD or card.
@rajamalik Aye aye Sir. I just hope Vegas has all the nifty plugins I'm so used in Premiere cause otherwise, even if I love Vegas I wont be able to switch.
@Aashay Are you trying to play directly from the card, or are you copying over to your hard drive first?
Try Vegas 12 pro use mts directly for the edit @Aashay
@rajamalik.. cheers dude.. I have a quadcore AMD with 8 gig RAM and Nvidia gtx 460 1gig card that has CUDA enabled.. Still, it has problems even playing back single footage from the card..it stutters in VLC and Media Player Classic.. I use CS6 and MB.. but Magic Bullet cmpltly brings the process to a halt so I use Mojo mainly. Could this be some codec error? PC is virus free and recently formatted.
@Aashay Sedna aq1 a writes file around 140 Mbps average to 146 Mbps it's maximum is 154mbps . so it will work well in any 45mb/s class 10 cards. It will work well in a 8gb ram system with a good dualcore processor system. Performance varies due to graphic card and nle. Sony Vegas 12 pro with red giant magic bullet is a good choice for u r system. Anyways try and write back to our members
@Mirrorkisser thanks.. Also, I use a 64gb 45mbps sdxc and luckily I havent had any problem with any patch (unless it's very experimental).. Does Sedna produce huge file size? My PC has just 8 gb RAM and Premiere starts to slow down during long projects,so I was thinking of dnxhd proxies but don't have TB's of free space..
@Aashay: i would use Sedna all the way! They are known for their reliability, too.
So between AN and SEDNA AQ1, which one would you recommend for 24p narrative films.. Would love some cushion when it comes to grading..
@jnphan or you try valkyrie, gopzilla or flow motion they are fine, too. In the end it depends what kind of SD cards you use and what you want to do with your camera. Without that its hard to tell which setting to use.
@jnphan: "Cluster v7 Apocalypse Now - DREWnet/ sharp2" and "SEDNA AQ1/ A" are the best settings for gh2 by far.
Help! Please, what is the best/ most reliable hack? I am so confused! Please help me, thank you! :)
Thanks for this great patch! For low-light, what would you guys favour : Canis Majoris Night or Apocalypse Now ?
@AonAnderson After a span you have to record a very short shot (couple of seconds) before recording again. This is really the case with all the high bitrate settings when it comes to spanning (IIRC, someone correct me if I'm wrong, I never have to span because I never have shots that long so I don't worry about it). Also Cluster V7 is a long gop setting and the Sedna settings are GOP 1 Intra settings, which you need to know. This means larger files, less space on your cards etc. If its longer GOP settings that you're actually after then check that thread for other cluster like settings with other matrixes if you're not happy with the AN matrix.
