Here we go to the next headphones.
Not pricey, available at ali:
Really good looking headphones, and made to the same high standards as Pro 80.
As for comfort, they are very similar due to similar design. Ear pads are more comfortable on 2050.
Same thing must be said about large head. Be very careful, as these can be uncomfortable if you have one.
This ones have most pronounced sibilance. They are quite bright with punchy bass. Less monitor like, compared to Pro 80.
But sound is very good.
I got images above from http://www.wapy.com/entiz/read.php?num=4816
Small article in Polish (you can use google translate)
http://forum.mp3store.pl/blog/53/entry-81-takstar-hi-2050-%26-8211%3B-chinskie-hi-fi/
Those look like Beyerdynamic clones in design, like the DT880 or the T90. Interesting nonetheless.
Yep, similar design. But sound is different.
Beyerdynamic DT 990 PRO inside. Very similar approach to damping :
DT 880 :
Similarity in other things
How large?
How large?
How large what? Sound difference?
No, the head!
No, the head!
Mine is not small :-) If I like TS-671 as most comfortable HP it say something (and this is largest HP I tried personally).
I like these HP, they probably sound decent with this setup, and look good. I tend to do lot of faster projects mixing with HP, and I need to replace my current ones that have 1kg of glue, tape and soldering stuff.
IF you ask me - I suggest to get Pro 80 + TS-671. As set. Pro 80 is most flat of all three. And TS-671 is most open (drivers lack any damping contrary to most so called "open" HP, hence lacks some bass).
Note, same headphones available now as ISK HF2010 below $41 shipped
Another brand, same phones Bingle B910-M - $49 on sale
Thanks for deals links for this phones. Exactly the thing I had been looking for.
These phones are the same of Arcano SHP80.
The SHP80 and SHP300 are the best selling phones here in my country Brazil.
SHP80 is similar to: ISK HF2010/ Takstar HD2050
SHP300 is similar to: ISK HP980/ ISK HD9999
