Lenses and rig will outlast the camera. Yearly cost might be quite low.
True. The key is not to switch camera systems every time something new comes out.
@QuickHitRecord, oh I should have specifically said the total cost of the mate box setup. I know, things can quickly add up. I have a collection of lenses that I have invested on that I will always use. I am just looking for a small and versatile mate box setup that will do the job and it's seems like this setup will be just what I need.
@HillTop1 The mattebox itself was $208 on B&H. From Cavision, the swing away was $60. Metal filter holders were $30 each. The specialized step up ring was $35 and shipping was $16.
@QuickHitRecord, thanks appreciate it.
Its a pitty that they constructed the swing away that way. It wont work with wide angle pancakes, even without FF attached...
@Meierhans For a wide angle pancake, you could just use a T-bracket.
Of course. Or even a good quick-release.
I've never had much luck with matte boxes on wide angle pancakes, anyway. Not enough room for comfortable handling of focus ring, either directly or via a follow focus..
Which brings me back to the philosophy idea of travelling light and the mini M/Box being really at its best with auto/semi-auto lenses. I use the 3x2 with pancakes a lot. While I can hardly get one finger into the focus ring, the wide lenses stay in focus while there's light and a quick touch on the LCD screen does the rest.
Not sure if this is the place for this, the topic is about small 3x3 matte box, but this is related as it's about using small lenses with matte boxes.
I use Nikon AIS primes which are quite small lenses. I'm looking for a matte box and I've noticed that this may be a problem with small lenses. I'm using the Lanparte rig and follow focus.
Just wondering what anyone's experiences are using small lenses with a follow focus and matte box, is this problematic? Does anyone top rail mount their follow focus or matte box if there is not space to put both on the bottom rail?
Any pointers as to using smaller lenses with FF and MB?
Thanks
I also use Nikkor AIS lenses. Consider looking into a conical step ring like this attached image. They are designed to adapt the front filter thread of your lens to the threadless inner diameter of your matte box, but they push the matte box further away from the camera (the cone shape helps prevent vignetting) so that you have space for a follow focus.
@QuickHitRecord - Thanks for the info, I'll check them out.
I have an update. I have replaced the swing away with a "slider base with support mount" from Lock Circle: http://www.lockcircle.com/matbox/buy/ (second item)
It is the only system that I know of that allows for the mattebox to slide back and forth on the rod system as lenses extend during focusing. The Cavision T-bracket fits inside the groove cut into the slider base. With long enough rods, it is easy to slide the matte box forward when changing out lenses, making it just as convenient as a swing-away. I keep an M10-1.5 bolt screwed into the end of one rod to stop the matte box from sliding off.
As a bonus, I have discovered that with a Duclos focus ring of a certain depth installed at a certain point on my SLR Magic 12mm's focus ring, I should be able to get my Edelkrone FocusOne Pro follow focus AND my 3x3 Cavision mattebox to work together with my GH2 with no vignetting. I'll be sending the lens in for that modification soon.
@goanna @QuickHitRecord I will probably be getting the Cavision 3x3 Matte Box and 8mm rail system. I was wondering what you liked in terms of good quality 3x3 ND filters and 3x3 Circular Polarizers (or Linear - I only shoot manual)?
I am happy with my Cavision 0.6 ND and 0.6 graduated ND. Less of the hue & fog of the cheaper ones. No Pol Circular.
To fit the mattebox's 82mm rim, I have permanently fitted a wide Cavision 77mm-82mm adapter. The default filter size for each of my lenses thus becomes 77mm and each lens has its own step up adapter; 37-77, 49.5-77, etc, permanently attached and at the ready to be fitted to the mattebox.
@goanna Sounds like the Cavision ND is pretty good. I think I remember seeing them priced pretty reasonably too. Assuming cost isn't an issue, are there any other 3x3 ND filters that will give an even better result in terms of no image quality loss or resolution loss?
(That's a cool solution with the 77-82 permanent adapter and then prepping lenses to fit to matte box. I'll probably go with rails, as the 3 lenses I usually use each have an obstacle to that solution.) Thanks
Cavision has released their version of Nuns Knickers for Matte box. Only $20 http://cavision.biz/adu085-d45.aspx
Anyone using this matte box with a Nokton 17.5mm lens? My concern is if this matte box interferes with the aperture of the Nokton which is very close to the end of the lens. I had a foot injury last year, and now a knee injury, so keeping things light is great in theory, but I also want something that works with the 17.5mm because it is on my camera 99% of the time. I also intend to use it with a TrustMT follow focus. Not sure if this is relevant.
OK, well never mind, I bought the matte box with one of the cavision rail systems with the matte box mount, as well as the donut adapter (nun kicker thingy). I expect everything except the donut within a week, and will give my thoughts shortly after. It's my first matte box, and rail system though, so take it for what it is.
Just a quick update. I received this Last a little over a week ago, to Japan just 3 days after purchase from B&H! Other than a few minor issues like loose screws, and the slightly bigger issue of a couple screws that did not match the ones in pics online which caused problems with moving the flags inward correctly (easily remedied), this little matte box is working nicely. It is so light, but is holding up fine. I will post a video review showing parts of the unboxing and the problems I encountered along with the remedies in the near future. Busy busy right now.
I have been very busy lately, but just wanted to update that I received the donut adapter, and it fits like a glove with the clamp loosened a bit, and then just a slight tightening and it is very secure. Looks great too with it's leather sleeve (pretty sure it is real leather ) and snugs very nicely around the lens barrel. Still planning on posting a review, just may not be for a bit.
On the subject of "Making do" with a 3x3 matte box. I would say 99.5% of the time, you could make do just as well with screw on filters and a french flag to stop flare. It just wouldn't look quite as cool. But a lot more affordable and just as practical.
I'm interested to know hoe this Cavision rails rig has panned out for you -
Do you find you use the rails always, or sometimes just pack the matte box? Have you added the nun's knickers?
I personally find I often pack just the camera and would sometimes prefer a tiny (read:minuscule ) hood just to cut flare, just for ease of travel. I wonder whether the 8mm rails (yes, 8mm) would turn my M/B into something more useful while not too much bigger.
Not to be sneezed at, it's true! But this is a learn-your-equipment-by-heart thing, which might merge into a lifestyle thing, being fast and comfortable with what's easy and appropriate.
For example, think Friend's Wedding Reception, Hawaii. You're there, champagne flute in one hand, chatting to buddies, your GH.x with its tiny mattebox on a monopod on the other hand. Occasionally, moving around the lawn, you might slip the ND filter back into the shirt pocket of your Hawaiian shirt, change filters and get some footage, all with discretion, keeping up the conversation and eye contact, once again taking your glass from a table to drink a toast....
Meanwhile, it's Sunday and I'm off on my bicycle to the street markets with GH2, mattebox and a sockful of rice for tabletop shooting.
