I couldn't sleep last night .. kept looking at this cheap roll of 300 LED lights I had purchased for about $3 on ebay in an auction. The seller wouldn't sell me multiple units at the same price, so my original idea (which I forget what was) just got put to bed.
I came up with this .. it's a piece of foamcore ($9 locally) and some tinned copper wire.
It's simple series wiring .. runs off 12 volts.
These particurlay LEDS are a little green, as is usual, when I am inclined i might tweak it with a sheet of minu green.
Here is a link to the type of LED strip I used.
http://www.aliexpress.com/item/DC-12V-72W-5M-300Leds-SMD-5050-Cool-White-Flexible-Led-Strip-Light-Waterproof-Led-Ribbon/632409382.html
I could onlu seem to attach 1 image in that first post .. js hiccup
The intention is that those who are desiring a larger LED light can run with this idea.
I might look at some more expensive LEDs (~$20 per 300) .. Could easily pack 1200 into the same area. For under $100 .. correct it with minus green .. and diffuse it.
