@bikepope. You can go up to 99 if you want to.
@thepalalias I was referring to this one "Driftwood Cluster v7 'Apocalypse Now' - 6 GOP Nebula '444 Soft' matrix" and I read now that it has 720 etc.. but why are their three different patches under the description? I just want to make sure I do this right hahah. Also will this patch work with the extreme 45mbps? Thanks again. I really appreciate it.
@bikepope you can keep it at V19 if you want. You don't have to increase this every time. As long as the number is above the original firmware you should be fine.
Hmm.... I tried this, but it only worked when I increase the number. Thanks
hoe come the bitrate on this driftwood patch is lower than the old 88MB EOSHD UNIFIED?
@bikepope: for me it also works with lower numbers, as long as its above the original firmware.
@getmezzy:different settings different bitrates. I recommend not using the EOSHD settings, i had some stability issues with them and others reported the same to me. The most popular settings outthere are by driftwood, lpowell, bkmcwd and ralph_b. They all have their strong sides.
By the way, all AN settings by driftwood work fine on my 45MBs extreme.
Nick, please make new topic, as this is very large one already.
I'll close this one later.
Our entry into a 24 Hour film race using Driftwoods latest:
The required elements for the Competition were:
Dialog: "This is not going to have a happy ending"
Prop: Keys
Theme: 'Catch 22'
THIS SERIES THREAD WILL BE CLOSING SHORTLY. PLEASE SEE 'DRIFTWOOD SETTINGS - EXPERIMENTAL SERIES' FOR CONTINUATION.
