GH2 Flow Motion v2 - 100Mbps Fast Action Performance & Reliability for Class 10 SD cards
  • 1036 Replies sorted by
  • @jdmproductions1 Yeah I think thats what happened to me, does your HBR mode also fail after 4 min?
  • @valpopando Do you live in Italy? Seeing such an epic example of a ghost town in this condition makes me so incredibly jealous. I can't even imagine all the amazing things I could shoot there, I almost can't believe it hasn't already been used in a major horror film. Puts things into perspective when a few old wooden shacks around here in the States can qualify as a ghost town; then you see this... damn.
  • Links to downloadable video files from the comparison at the top of this page:
    Flow Motion v2.02 (unedited 200% crop):
    Apocalypse Now - Boom Flat 4s (unedited 200% crop):
  • @LPowell says " ...the Flat 4s matrix is extremely sharp..."
    ?? excuse my ignorance but at first sight , Apocalypse Boom Flat 4s matrix looks like blurred compared to FMv2 , IMHO there is somethings that i didn't understand?
    @L1N3ARX LOL you can't believe how many place like that there are in Italy ! no one has made a horror movie yet , cause most of the houses are in danger of collapse, in fact there are barriers with signs prohibiting access... anyway we entered LOL
  • Interesting comparison. Thank you. I like BOOM! and flowmotion a lot. Most of the time i stick with flowmotion though, because it takes less space and i never had any stability issues. Still the new matrices by nick and cbrandin really appeal to me. Visually they offer something new, i cant comprehend it on a technical level, but although they have their flaws they have lots of character and look cinematic. Just like an old soviet film lens.
    @lpowell: what do you consider an intra settings strenghts compared to longer gop structures?
    And what about a comparision of the new valkyirie settings with flowmotion? They use the same goplength and they contain cbrandins 444 matrix in its purest state.
    @valpopando: as far as i understood lpowell it tries to be extremely sharp but then runs out of bandwith etc so in some parts of the frame the image quality really drops. It has to be said though that Nick always said its an experimental setting and it was not recommended for wide or super detailed shots.
  • @LPowell I really don't understand the comparison Lee. Boom and Flow Motion are two different animals. Nick states flatly that Boom isn't intended for wide shots or 720. It's an experimental close up setting. I don't entirely agree with that and I have had good results in extremely low light.
    Flow Motion is the action setting I and many others go to. I wouldn't consider any other for sports or fast moving events.
    Why bother to compare apples and oranges? The constant 200% views and insults are distracting from the extremely good work you both do.
  • Have to agree with peternap on this one.
    I tested the FM against AN boom the other day (same shoot). Not surprising, the AN contains much finer grain and almost zero mud compare to the FM. Big difference. Its not possible to raise the shadows with FM in the same extend without introducing digital noise. The all-I really shines in that part. Didn't notice any difference in sharpness, but that probably had something to do with the shoot by it self (low light, f2). The FM is good for run N gun with great results, but sadly can't be pushed that hard in CC when it comes to a low light situation.
  • I think those comparisons are still interesting though and i am thankful Lee does them. It gives me a hint which setting might be good for me in which situation. But i think its not good to play those settings out against eachother, because both have their strengths and weaknesses. Both serve their cause.
    @peternap: can you recommend me a good intra setting? Good in the sense of reliable and very good picture? I like BOOM! a lot, but its a rather specialised intra setting. I am looking for a good allround one. Cheers m8
  • @peternap
    Have to disagree with you here, strongly. The typical post in these forums, raving about one setting or another, consists of footage which is impossible to evaluate -- nothing to compare it to, changing in-camera settings, web compression, unknown levels of image processing, different lenses, hand-held shots v. locked down shots, etc.
    If somebody simply knows, without rigorous examination, that one setting is better or "more cinematic" than another, great. That person has found happiness. The trouble is, nobody knows what "better" or "more cinematic" (crushed blacks? de-saturated highlights? is this necessarily good in "raw" footage?) actually means in the mind of the writer or whether the claims made would survive scrutiny or a double-blind test. So the discussion is useless.
    An actual comparison may not be the last word, and we could disagree on what the ideal comparison shot is or whether the conditions were adequately controlled or how the footage should best be tested (stressed in post?), but it's a hell of a lot better than the usual raving for one setting or another which typically goes on here.
  • @ jrd: i totally agree with you. Comparisons that are not polemic and not just simply exploit weaknesses of a setting to let another setting triumph, are really usefull. For me its sometimes a settings-jungle. Each party praises its own setting, but that does not help my comparing.
  • @Mirrorkisser
    [Apocalypse Now Boom Flat 4s] tries to be extremely sharp but then runs out of bandwith etc so in some parts of the frame the image quality really drops. It has to be said though that Nick always said its an experimental setting and it was not recommended for wide or super detailed shots.
    That's right, I used Elecard Streameye to examine the macroblocks in an AN Boom F4s frame, and found that it was able to maintain its initial QP of 18 only in the top row of macroblocks. In the rest of the frame, QP ranged as high as 34, which indicates very coarse quantization. As Chris Brandin explained in earlier posts, the encoder will attempt to maintain QP consistent within a range of 5 around the initial QP level. In all cases where I've seen QP break out of this range, it was because the encoder was being forced to operate at an excessively high level of image detail that required more bitrate than it could sustain.
    While it's true that AN Boom F4s was released as an experimental patch, it has generated a great deal of interest as Driftwood's latest offering. I was interested in it primarily as an example of using maximum bitrate to record as much image data as possible. My initial tests showed that it would fail consistently on highly detailed subjects in 80% Slo-mo mode, so I chose a simpler scene for this 1080p24 comparison test.
    As can be seen in the Stream Parser report above, this is a scene that Flow Motion v2.02 encodes at its finest image quality, maintaining consistent QP levels within the encoder's standard 5-level range. That makes this FM2 example a good reference point for this test, since it's performing exactly as it was designed and intended to work. This is a relatively simple scene that I would expect any well-designed patch to handle without straining its resources.
    Frankly, I was surprised to find that AN Boom F4s had so much difficulty encoding this scene at its intended quality level of 18. What that indicates is that its Flat 4s quantizer matrix is demanding far too much bitrate to operate consistently at a QP of 18. Since 150Mbps is close to the peak bitrate the GH2 can reliably sustain, my conclusion is that either the target QP of the patch needs to be raised significantly higher (i.e. coarser) than 18, or the Flat 4s matrix needs to be replaced with something more realistic.
  • Please make love not war !!!!!!! so STOP to fight and enjoy my VESUVIO lapse short video LOL ! of course made with Flowmotion V2 hack
    have a nice WE
  • @valpopando Thanks for uploading your footage, it looks beautiful. If presenting independent, objective test results is considered an Act of War by Driftwood and other enthusiasts, then it's a "fight" I'm prepared to engage. I fully understand that the Apocalypse Now Boom Flat 4s settings are experimental, and so I chose a relatively undemanding scene to test it, rather than one designed to break it. I limited my evaluation to technical issues where its performance appears to fall short of its intended quality level. Hopefully, these test results will provide insight on how the patch can be improved to maintain a more consistent range of image quality.
  • @LPowell, would you be kind enough to conduct the same test with FM 2.02 VS. Valkyrie C5 444 to see how the two of them compare? Plus, they are both 3GOP and in the same category. Thanks in advance.
  • @lpowell i like your comparisons. But please dont make them feel like an act of aggression.
    I am also very curious how valkyrie 444 does compared to flowmo. Valkyrie is really great, just the file size rapes my hdds.
  • @Zaven
    The notion that patches should only be compared to other patches that use the same GOP-length is hard to justify from an audience's perspective. When you watch a video, its GOP-length is irrelevant. It's the visual motion picture quality that counts. Regardless of the encoding technique used to capture a video stream, its image quality can be objectively compared to any other type of encoding.
    I've found bkmcwd's patches interesting and helpful in developing Flow Motion v2. The main problem I've had with running formal test comparisons is the same as with Driftwood's - they both release so many dozens of versions of their patches that I'm honestly perplexed on how to choose among them all.
    Apocalypse Now Boom Flat 4s stood out as the most extreme patch of its type. Its unrestrained use of brute force encoding techniques cannot be pushed any farther on the GH2, and that makes it very interesting as a test case. I'm looking forward to testing bkmcwd's final release candidate of Valkyrie C5 444 as well.
  • @LPowell... I hope someday I can meet u so I can crack this stubborn streak u have...
    bottom line, when i have a highlight on a face; or hot spot in the background, gop1 FEELS far smoother than gop3 in playback... ya? not a screenshot, but how it FEELS wheen played back on a screen. nomatter what.... everytime i have compared I can see the compressed B or P frames....
    and the 1gop grades better.... like i have said to you before, I want a flomotion 1gop patch, for an HONEST COMPARISON
    ... ya dig? wheres the flomotion-INTRA????
  • @flaschus
    Should I take that as a threat?
  • @LPowell,,, I was being sarcastic in order to develop rapport. professor chaos.
  • I wounder if this is the kind of analysis they had at Panasonic between codecs before they decided on an intra codec for the GH3. They are the only ones who know how to really improve on what they have created for the GH2. All other efforts have been achieved with great length and much praise, but do we really need to have such pissing matches at this point after so much has been done to get this far. LPowell and Driftwood are relentless at every step and I'd rather see everyone shake hands and try to do something together as a team instead of trying to prove one is better than the other.
  • @flaschus
    Thanks for your honest sarcasm. As for GOP-1 versus GOP-3 playback, the motion quality is crucially dependent on the playback device. In my own tests of Flow Motion v2, I have been consistently unable to spot any perceptible differences between its I-frames and its B-frames. The screen shot I uploaded at the top of this page is actually one of FM2's B-frames, compared to an I-frame from AN Boom Flat 4s.
    One reason I haven't developed a GOP-1 all-Intra version of Flow Motion v2 is because it's impractical. The peak bitrate of that test video is around 100Mbps, and the average size of its B-frames is about 300Mb, plus 800Mb for the I-frames. To maintain that level of image quality, the GH2 would have to operate reliably at a peak bitrate of over 170Mbps, well beyond the maximum bitrate I've been able to achieve.
    What's worse is that setting 1080p24 mode to GOP-1 forces you to run 1080p25 HBR mode at GOP-1 as well. With Flow Motion v2, I was unable to achieve reliable peak bitrates higher than 100Mbps in HBR mode, and that was with a GOP-3 setting. Changing that to GOP-1 would have significantly degraded the HBR image quality I was able to obtain at GOP-3.
  • @LPowell After shooting with flowmotion v2.02 there ain't no going back... let me just say you did a find job with this hack Powell. Just wrapped-up a video shoot today let me tell you Reliability: A+, Quality: Top notch the best I've seen, Motion: The best motion, or if you wanna say cinematic motion I've seen in all the patches. 720P: Very stable and the the quality exceeded my prior cam Canon T2i sorry Canon had to let you go. I will post video sometime this week. Great work my friend cheers.
    GOD Bless
  • @Vitaliy @LPowell @driftwood @cbrandin Hello Gentlemen, I must say that the strange reactions to criticism has begun to tear apart this adventure. Here in the great US we say opinions are like assholes, everyone has one. I think I have been here for maybe 2 years now and have continually been amazed at the camaraderie that exists here. Now it is competitiveness, the minions are gathering, pushing the individual teams to side. This is crap, are we forgetting what brought us here in the first place. It still blows my mind when it look back at ALL the patches and laugh at the beginning. I was knocked off my chair when I was testing Driftwoods 244, wow. When Vitaliy, would tell me wrong place, or read the wiki, it was good and It can be again. LLPowel ready for confrontation. Come on. Most of the posting here, no matter what patch is being used is more for what, Hey remember the fundimentals, Light, Composition, Lens , not this, "can you tell me what is the best patch for my job that I am shooting tomorrow"? Figure it out for yourselves, Test. These people have moved all of us forward,(@Vitaliy @LPowell @driftwood @cbrandin) made us wonder again. Opened our minds to the possibilities with this little cheap ass camera. I do not know where most of you came from, but I know what it is like to carry a full dress Panvision camera up a hill side, its is not fun. So please respect one another. Sorry Vitaliy, may be this is not the right place, it was the only one that might be read. Thank Guys, your great.
  • Test: Medium and close range shooting with Flowmotion v2.02 - awesome soft Graduation - very good sharpness - realistic color - a good film look - Lens: Nikon Nikkor 55mm f1.2 AI (legend and built to last forever ...) all clips out of cam - no color grading etc. - native rendering with vegas pro 10
    thanks Vitaliy Kiselev (master GH2 Stalin Hack) and thanks for LPowell Flowmotion
