LED lighting setup for interviews
  • Hi everyone - haven't been around here much lately. Been happily busy with my GH2 shooting docs, corporate vids, etc... Thanks again to everyone who put time into the hack. You guys are great.
    I was hoping to get some recommendations on lighting and grip gear. I have a budget of about $1500 US total for everything. I'll be doing a combo of Craigslist for the grip gear (found some c-stands and sandbags for a good price on there) and Amazon/Rest of the Web for the lights.
    My main question is in regards to how many lights you all would recommend I get for a starter kit? There is a good deal on the CN-900 light over at ePhoto's site. I want to grab them quick, given the sale price. Not sure how much longer they'll be up for that price.
    Light-wise, I was thinking about going with: 2 ePhoto CN-900 lights 1 ePhoto CN-600 light
    Originally I was looking at getting 3 500-LED bi-color lights. They're cheaper, but I'm concerned about the amount of light in a larger room.
    I read that Vitaliy recommends bi-color lights. But I'm not sure if the budget will quite work out for me on this one. It looks like I'll have to gel the single color lights.
    This is primarily for interviews, both interior and exterior with a battery. I've read about a couple options on batteries.
    Also, I will be shooting a short in the next couple of weeks. It's a single location, single-camera sitcom-style short. The main location will be a (hopefully) medium to large basement-style room.
    Thanks!
  • 27 Replies sorted by
  • Here's a little tip on how to fix the barn doors on the ePhoto 4-banks. Grab some Permatex Medium Strength Threadlocker Blue from your local hardware store. Take off the 4mm nut and coat the thread. You can replace the nut immediately with the wrench. I let it sit for about 10 minutes to let it harden a bit. Seems to work very well. One the first flap that I tried it on, the nut on one side moves a little, but not so much that it unscrews. The other side stays perfectly. This is great news in that I can use the barn doors again!
  • @vicharris. Thanks for the recco. I am aware of minus green. Just looking for the equivalent to a 1/8 plus red.
  • @5thwall Love the bag! That's awesome. How much did you pay for that again? As for the minus green, they make it. I have 1/8 and 1/4 minus green, or magenta that I use on mine. Expendables should have it.
  • @Vitaliy_Kiselev I'll be shooting with the lights in a week and a half. Will post some of that footage when I get it. In the mean time, I've attached a pic of one of the cases for the fluorescent 4-banks. And below is an all-too-lengthy explanation of what I ended up getting and experiences thus far.
    One gripe about the fluorescents is that I have to echo @vicharris about the barn doors. They are crap. If anyone has figured out a way to get them to remain in place, please let me know. I think it's just a cheap design. I'll be resorting to gaff tape in the mean time.
    Oh, and don't buy the Cowboy Studio 2-bank. I wasted a week on those after a return and replacement and then another return. Bad ballasts on both units. And the tech department and customer service at CS was crap as well. I guess I shouldn't be shocked. We all know it's cheap stuff. But still...
    I checked the color balance on the lights with the GH2 set to 5400k and a gray card filling the frame. At 5400k, they are very close with a little bit of a pull toward cyan. Maybe a 1/8 minus green would help. Need to test that next week. Does anyone know what gel would be the most like a 1/8 red? There is no 1/8 red, that's why I'm asking.
    The light panel was an el-cheapo ePhoto 900 LED. I know, Vitaliy, you recommended that I go with a better model. I just need it for fill in outdoor and had a budget to keep. I color balanced that one, too. It pulls toward cyan/green. Again, will look at gels for it next week. The built-in magenta and "tungsten" hard filters are useless. I actually found the diffusion filter helped bring it closer to the center mark on the vectorscope.
    Got a Switronix SWXPL90SK1 Power Kit from B&H for the LED. They seem to be perpetually on sale. Also got an XO Vision XO420 350-Watt Power Inverter with 2 AC Outputs for powering a light or two from the 9V in my car.
    After testing the XO Vision, I was able to power the 900LED. Separate from that, I was able to power 1 bank of one of the fluorescents lights. I wasn't planning on using the flo outside, so it's just good to know what it can power. I've been looking at a Power Bright PW1100-12 Power Inverter 1100 Watt 12 Volt DC To 110 Volt AC which attaches directly to the car battery for more intense setups where I can get far enough away.
    Reason I'm looking at using the car battery power for lighting is that I was on a shoot in Bakersfield a few weeks ago and this really would have come in handy since we need to block sunlight outdoors and needed to key the talent. Since I didn't have the battery, we couldn't do it, unfortunately. The shoot lasted a couple hours, so a single battery for the LED probably wouldn't have lasted.
    For stands, I got 3 Ravelli ALS Photo Video Light Stands. They seem fine. People on Amazon like them. Sandbags will help. The light stands that came with the ePhoto Flurorescent kit are pretty cheap. I am using one of them for the 900LED since it's so light. I'm using the other one with a Pad Prompter.
    BTW, the Pad Prompter is kind of expensive, but it works as advertised. Ended up getting Teleprompt+ for both the iPad and the MacBook (which can control the iPad app). It all works fairly well. You can't edit the files on the MacBook that play back on the iPad app, unfortunately. I'll say this, it all works well for the budget. But it doesn't work as seamless as a high end teleprompter with a proper remote. I'll be testing it out next week, as well.
    Ended up getting 2 c-stands and sandbags from Craigslist. I'm unhappy with that purchase. I was in a "gotta get this stuff now, frame of mind." And I just sort of thought that C-stands always stand the test of time. For the price I bought them for, I could've spent relatively a little more and bought new ones. In any case, I got a new arm for one and I'm using the other one specifically for flags and scrims, which will be fine.
    I won't really know how this will work until next week's shoot. My feeling is that the fluorescents will flow. They'll look good as is or with a little minus-green. The LED will do well as a creative light - add a strong filter or use it as a hair light or something. Haven't seen the location yet, so not really sure what our options will be.
    Thanks again to Vitaliy and Vic for their input.
    2592 x 1944 - 2M
  • @5thwall
    May be make small video about lights and this cases?
  • Hey y'all. So I got my LED light panel and 3 4-bank ePhoto fluorescents. I'm pretty happy with everything. Just wanted to give a shout out to an amazing company in Burbank who makes custom light cases, flag cases, etc... I like supporting the little guy (or gal) and it doesn't get much littler than Sita's operation. She didn't ask me to post this and I'm in no way affiliated with her company, I'm just very happy with the work she did on all the bags. If you live in LA, and need very reasonably priced bags for your lights or gear, I highly recommend giving her a call. Her site is http://stufftproducts.com.
    If you are out of town, my only recommendation is that you talk to her to see if she can help. She needed to keep my lights for a couple days so she could size the bags properly. Everything is sized to fit snug.
  • Yep, they rock for that fast stuff. Weird being in the back of a house though. First time I went there I was so lost.
  • That's the one.
  • I take it you're in LA then? The place in Van Nuys?
  • Yeah, I've got some calls out for some -green. There's an expendables recycling shop that I'm hoping has some.
  • You'll need some -green too. Prob anywhere from 1/4 to 1/2. It never hurts to knock em down with a 1/4 :)
  • That's great news. Look forward to hearing how the bag works for you. I ended up getting the 2 4-bank kit. I also ordered a 2-bank 550W for fill light. Also picked up 2 c-stands and some sandbags off of craigslist today. Pretty decent price for some well-used c-stands. And the guy threw in some 1/2 and full CTO - so that was really nice of him.
  • @5thwall The dimensions are 25x17x4 but they have mounting attachments on a long side and a short side that can come off. I'm actually going to remove the one along the short side so they mount flatter. That should make that dimension about 22-23.
    It also looks like someone else is using that bag for the same lights so it looks prefect. I'm going to order one and see!
    It'll be in on Thur and I'll let you know
  • Thanks - much appreciated and will look at the 312s.
  • I would hold off on the 900 if you're going to get two of the kinos. I'd go for a set of the 312 bi-color LEDs on here that Vitaliy got a deal on. They have great reviews and you can dial them right in to the kinos instead of gelling to match. Lee just came out with a specific gel for led lights that match them to 3200k but it still is off a bit from the flos from what I can see while I'm editing. Still needs some -Green.
    As far as the case goes, I'm not sure. It might be too small. Think I've taken a look at it before but I'll go measure the kinos tomorrow and let you know the true dimensions.
  • Thanks, Vic. All excellent info - and your stuff looks great. I went to film school back in the 90s and yet I feel like I'm learning everything all over again.
    So my current thoughts are 2 kinos, 1 900, and possibly 1 500 bi-color.
    Can you gel the 500 to get it close to the flos?
  • It changes all the time. I really don't have a set way as I'm still learning. I just keep trying different combo's out till I like what I see. There's a lot of guys who are MUCH more experienced than me on here that could help. This setup was 2 Flo's behind the guys facing a white wall to blow it out and give it that PSA look, then used another one off to the left of them as the key and knocked it down a couple stops, then threw the 500 LED behind them as a hair to try and give some separation. In narrative stuff and improve webseries stuff, I use the 500 as a fill sometimes but it's so hard to match with the Flos. It's one from Fancier I believe and it's just the 5600ish one. 1st gen I believe.
    As far as stands, the ones that come with the Flos are pretty damn good. I didn't get one with the LED, so I purchased another one like the flo one for it. Rock solid.
  • Also, how are the light stands that it comes with?
  • Thanks, Vic. I was literally just looking at that on Amazon. Good timing! Which 500 did you go with? Is it the bi-color?
    How do you typically find that you set up your lights? Do you use the fluorescents as key and fill and the LED as a back light?
  • @vicharis, @vitaliy_kiselev Hey guys - thanks for the advice. Which Kino knock offs do you recommend? Vitaliy - if getting only one LED, which size do you think? 900, 600, 500?
  • +1 on the kino idea from Vitaliy You can pick up some cheap knock offs and use good bulbs for better CRI. I think I paid $225-$250 for each 2ft, 4 bank I bought and love them. They don't dim but that's all too easy with some ND. Here's a couple screen shots of a PSA spoof I shot with them. Testimonial style. Don't skewer me for the resolution! It was shot with a HVX200, original model, so it's not the best but the lights still work well for it.
    975 x 515 - 313K
    976 x 520 - 284K
