@apefos absolutely, completely understand. Just wanted to point out that there are more uses for a high quality w/a adapter than just getting as wide as possible. (in regards to your discussion with Ralph B above)
@RRRR @Ralph_B What i can do is after finish the anamorphic adapter, do a wide angle version of it, because if it works good in the cilindrical way it will be ok in the spherical way also. but there is some issues in the wide angle adapter we just would see if it get made: the barrel/pincushion distortion.
@apefos; another point re: wide angle adapters; it would be really cool to have one that works ok f.i. with a set of Canon´s or Nikon´s (where the widest prime may be not quite wide nor fast enough). Obviously it´s not easy to make it so that it doesn´t interfer too much with the quality of the prime but if successful it would be a tremendously useful lens. Suddenly you double your focal length options. 0.6 or 0.7x would be enough IMO. But you need a lot of glass to make it work with 52-58mm filter threads..
Ok, I understood. As you can read on my previous posts i am trying to improve the IQ in corners and cancel the chromatic aberration. I am testing different lens power, lens curves, lens positions. the main optical formula i am using is F1V1+F2V2=0 If the anamorphic adapter works i can turn it into a wide angle adapter. But there is an issue probably i cannot avoid. When you add some glass in front of a photo lens you need to stop down a little to avoid blooming, glow and low contrast. Even if the adapter reach a perfect optical system, maybe it will need to stop down one or two fstops to get rid of that things. For the anamorphic adapter, work with f2.0 or f2.8 will be great, but it would not make sense for the wide angle adapter. Lets wait to see how the project will end.
The problem with most wide angle adapters currently on the market is they are designed to work with the lenses of small sensor camcorders. They are terrible when you put them on a 4/3 lens, APS-C lens, or full frame lens. So there is definitely a market for a high quality WA adapter. Why would someone put a WA adapter on the 20mm f1.7 pancake instead of using the 14mm f2.5? Easy, you get an extra f stop of light! Another example - many people have vintage 50-58mm f1.2 lenses. Wouldn't it be wonderful to use these lenses at full aperture with a wider field of view?
I would buy such an adapter, but it would have to be razor sharp to the corners.
@Ralph_B I can consider think about it, but only after finish developing the anamorphic adapter. The principle is the same, the only difference is the anamorphic adapter is cilindrical and the wide angle adapter is spherical. Probably they can share the same optical system formula.
But i have a question: why people would buy a wide angle adapter for the 20mm pancake instead of buying another prime? there are the 14mm 2.5, 12mm 1.6, 17mm 1.8, 10mm 2.8, 17.5mm 0.95, 14mm 2.0 and also the APS and M4/3 ultra wide zoom lenses...
I think if i can do the wide angle adapter it would not be so cheap to make it a better option just considering the price. The 14mm 2.5 is selling for 167 usd on ebay, the big manufacturers can make prime lenses in lots and lots of units and sell large volume and they have all the machines and tools and professionals working for them, so they can make things cheaper.
sometimes i start thinking this Anamorphic Adapter Development is a high risk work, similar to 35mm dof adapter because the big manufacturers can come with a cheaper solution. But i think the anamorphic adapter will survive in the market longer than 35mm adapters because they will not be replaced as 35mm adapters was replaced by dslr.
What motivates me most is some kind of diy virus. My intuition and knowledge keep saying: you can do that and i cant get stop until end with all possibilities.
Just wondering, could you take the knowledge you've acquired and make a high quality wide angle adapter that would work on lenses that cover a large sensor? For example, you could probably sell a ton of wide angle adapters that are corner to corner sharp on the 20mm pancake. I'm thinking in the 1.3 to 1.5x range.
With 100 self cost, you's sell it at best at $300. :-)
Yes @redstan i agree i need to make some money to help my living and pay my work. Man, i am working hard these last days.
So if i end up with 110 usd manufacturing cost to make the cheap version for camcorder, how much do you all think I can ask for selling it?
(the dslr version i do not now the cost yet)
as i said making anamorphic is easy but quality is tricky : ) even if your cheap system had of worked i still think it is crazy that you become a charity. why would you want to loose money making and selling unless you are very rich. if you work hard you need to be paid. it is very nice if people think you are fantastic human being and very generous but you still need to eat food and pay the electric bills : )
Now about the DSLR anamorphic adapter:
It seems i will shutdown the cheap version for DSLR. In my tests i could not do the single element version to work. it will never allow focus. So i did some tests with the two element design, but the chromatic aberration is huge and annoying, and corners are very soft and blur. Image Quality is a must for DSLR and nobody wants a toy lens anymore. I do not want to sell something i would not buy myself. and i think it does not deserves more try because IQ cannot increase without using more lenses in design.
So my conclusion was to change the route for the DSLR anamorphic adapter. The goal now is the best possible image quality, no more cheap route here.
So i went to my 35mm adapter archive and i started to experiment with achromatic lenses i designed some years ago. All lenses were designed by me and i got a zero chromatic aberration optical system in my 35mm adapter model called Apefos GEM with perfect sharpness in corners.
Using that lenses i could improve the image so much in the GH2 tests and i ended up with a FIVE element optical system design for the DSLR Achromatic Anamorphic Adapter. Image quality in corners improved so much, and also chromatic aberration in the esferical direction improved so much. The cilindrical direction will improve also, it will be tested when i get hands on new cilindrical lenses design. Using more lenses in design changes the lens behavior to get the squeeze factor, so i did some measures and will experiment new lenses design to get the 1.33x squeeze factor for DSLR.
All the five elements optical system will need multicoating.
Now it is time to wait the drafts to mature this weekend and take them to optical lab on monday. Of course i did not find the final design yet, i will try the new lenses when they become ready. Also focus is not so good yet, so there is a chance everything go wrong, i will do my best.
An important advice: if the dslr adapter works price will not be cheap, it will be expensive. it is being developed to allow the maximum image quality i can do.
Please, hold your expectations. I think now chances are fifty/fifty.
I was on tests from early morning until now.
I started with the cheap single element adapter. I found the squeeze factor for HV20 camcorder. it works and it is possible to do the 1.33x The chromatic aberration is very small and can be easily corrected in computer in most editing softwares, if the adapter works i will do a tutorial about this. The problem is i did not get good focus yet. i did some new lenses design keeping the squeeze factor and pursuing focus. i will let the drafts mature this weekend and monday i will go to the optical lab again. Image Quality and sharpness will emerge when i get focus. There is a chance the focus not work, so the cheap version can shutdown, but i will do my best to make it work.
I found some rules in the behavior of the horizontal flare, i could see it larger and smaller, but it needs more tests.
I did not found the behavior of oval bokeh yet, i could see it, not so much pronounced, but it was there, needs more tests.
Probably the horizontal flares and oval bokeh will be a result from the 1.33x squeeze design when it get focus and good IQ. This squeeze factor can be done with different designs but the problem is some designs needs larger glass and the difficult in grinding increases and the risks of glass breaking become an issue. i will try to improve these artifacts only if i can keep the cheap route, but it seems the oval bokeh and horizontal flare will be a result from the best 1.33x squeeze design when it reaches the good IQ.
i could do some zoom in and out in the camcorder, but zoom range decreases, after finishing design i can say the possible zoom range.
I did some tests with some strong backlight and probably the cheap adapter will need multicoating. this will increase the price a little. When i was talking in the @slrmagic topic my expectation was to do this cheap version spending 50 usd. slrmagic did an analises and they found it would be 80 usd considering my worktime. If multicoating become a must this will increase to 110 usd for manufacturing costs without making any money.
But remember: all can go wrong if i cannot find good focus, so lets wait to see the behavior of new lenses design in next week.
Hi @JohnBarlow, thanks for the tip, but do not need to worry about it.
In the optical lab they have some precise alignment tools and measuring equipment. So when grinding the glass they can do it with perfect alignment in the curves axis. all grinding are machine made. after polishing they put the lens in an optical/electronic equipment to do the measures in power, curves, axis and so on.
when aligning the lenses in the adapter body i can point the camera to a grid pattern fixed in the wall, with the camera perfect aligned in horizontal and vertical axis. this way i can rotate the lenses inside the adapter body and fix them when the squeeze is perfect horizontal.
Here is a tip you might find useful, I have not tried it but it should work and besides won't cost you much.
It is vital to align the cylindrical lenses very precisely to avoid distortion and lack of sharpness. A cheap pointing laser (< $10) shining through a cylinder lens will form a straight line so if you make simple rig with clamps and a screen you can mark the projected line on the screen for each lens, then you will know the positions for precise alignment.
Good Luck
i understand the point. when add a negative lens in front a camera lens, it changes the focus behavior and the camera lens need to change focus to macro. the dslr lenses do not have macro and the longer the focal length is the far the minimum focus distance is. i found in my researches that many dslr lenses can focus below 0.3m / one foot, including m43, aps and vintage lenses in focal lengths between 14mm and 55mm. After that focal lengths the minimum focus distance increase to 0.5m and even more, and its more difficult to get focus. this is why you cannot use tele lenses in current anamorphic adapters.
My goal is to try to get a close-up shoot with the adapter. because if it allow shooting a face close-up it will be good enough to do a movie.
I will try to get it to work with: from 14mm to 42mm or from 18mm to 55mm. This is enough to do a face closeup with gh2 and aps cameras and also shoot enough wide to show a room or a group of people. More than this will be difficult to do and will decrease image quality because chromatic aberration increase due to use more powerful lenses.
Hi all, thanks for following the project and encouraging me!
i got my hands in first batch of lenses (14 units), tests will start tomorrow, now it is night and i am a little tired, my mind did not stop thinking about lenses and body design these last days.
first tests will be: will the squeeze works? will i get the 1.33x? will i get focus? will focus be something about 1 meter to infinite? will i get oval bokeh? will i get horizontal flare? will the image quality be good? will i make it work with all the important focal length lenses?
there is a photo showing the lenses (as you can see i erased some informations at the side of the lenses):
@apefos btw would you be able to make diopter lenses too. I mean it is really almost impossible to find 95mm or 105mm that would work with LA7200?
@apefos Good luck and I really hope it works out! I will buy one for sure if the IQ is at least equal to LA7200.
I always wanted such a system. I was always asking myself why nobody did a higher quality anamorphic adapter as the Panasonic la7200. I have given up on the anamorphic look because the different solution had gone way out of price, or they were completely impractical. It was more like, hey look I have dome one shot that looks like a movie shot. The La7200 adapter was done in the days of SD, but people were getting some good result on apsc sensor camera. I don't have the money to buy a new set of lens, but a good adapter at a good price, sure I will be very interested.
@apefos I wish you the best of luck as well.
I hope it works out. Looking forward to your test footage.
@apefos Best of luck with testing them. :)
going to the optical lab to collect the cilindrical lenses...
@oscillian the 25mm is inside the focal length i am working in. also it has the 52mm thread size. i will try the adapter in some fast lenses to see if the image quality will be ok in these kind of lenses with large entrance pupil.
for lenses with different thread diameter step-up or step-down rings can be used.
thanks
