@vgtah I think you should take the PTool version 3.65D for Flow Motion - not the 3.66D also applies to the patch from Nick (!?) I think - or?
@butt i saw the acceleration, im speaking of the video mode that gives that animation effect, i knew it but i would like to know the set up precisely. I can t install the new firmware, im damned.
test with Flowmotion v2.02 patch of LPowell - I think the patch is very good - nice soft Graduation - good sharpness - awesome colors - illustration of water is great - a great allrounder - thank LPowell
natural -1, -1, 0, -2 Lens: Pana 14-42mm, Pancake, Nikon Nikkor AI-S 24mm f2.8
@vgtah I think you mean the video of @valpopando - He will have accelerated the clips in the post for this effect
@butt can you tell us which settings did you use for your crazy edit ? thats dope ! thanks
Hello is there a tutorial to install the firmware please ?,
i dl the ini file, i dl the 3.66 ptool, i had the v1.1 bin crack, i put it in the folder, then it doesnt works, i had to load the v1.0 bin file, it works....weird
thx for support
@valpopando three beautiful pearls :)
Apice Vecchia is a perfect set for a ghost movie
@valpopando - MeShUgGhAvertigo, wow, that is one hell of a flow motion test!
@Mirrorkisser Thank mate ! I should plan to comeback there at night time !!!!! Creepy Horror movie ; ))))
@valpopando:nice footage and such an exceptional place....
after a long holiday today Flowmotion discovered - heute V 2:02 going to tested here on the coast of the Baltic Sea - thank you for this patch @LPowell and curious how Flowmotion against Nebula 444
Here two short test filmed in some ghost towns in Italy. Nothing special , is just for share with You my satisfaction of Flowmotion 2.02 pacth . I did two hours shot without any issue or stop recording at all !! I want to say THANK general @LPowell , Vitaliy ,and to all those who have worked hard for us
and some crazy stuff LOL
I'm making some extreme low lighting tests using flowmotion and iso160. The only light in the room is the lcd monitor. I liked a lot.
@omarkenji Take a look here for general info: http://how-to-blog.tv/technical/corrupted-avchd-files/
There is also a tool from Panasonic itself that will scan the whole SD and revover anything that looks like a videoclip.
@omarkenji I take it the video was recorded in a single MTS file? Try importing the file into a video editor where you can examine the its timeline. If that doesn't work, contact me via PM. If you can send me a copy, I'll be happy to examine it.
HELP!
I Used flow motion v2.02 for the first time tonight, and I recorded a 9 minute clip that at first wouldn't playback in camera, it would say "this motion picture cannot be played" or something like that. So, I turned off the camera & turned it back on thinking it might fix the problem, but then now the clip wasn't even showing up at all..
So then I put the SD card into my computer and as it turns out, the file is actually there, but neither VLC nor Clip Wrap can open the file.. this particular clip is important to me, am I at a loss??
I agree on the patch. I use fully charged OEM when flashing the cameras. I've done it hundreds of times and still get that queasy feeling. If your battery dies while it;s flashing the camera or you hit any buttons during the process, it'll brick the camera.
@daihard Gotta watch out when applying a patch. Good to know, thanks! Man, my 3rd party battery looks so fishy. It works without any issues, but I think i'll just kill my wallet a bit to get some original stock batteries. I had a canon 7d and all kinds of wierd 3rd party batteries without any issues. time to play smart with the GH2.
@peternap @tasaraha I have Wasabi as well. After about 1 year, i "feel" the life of them has degraded... so dont trust estimated times for too long. I now ONLY use the Wasabi as an emergency backup when im running and gunning.
I still get great performance outta the stock and use a DIY power pack for my longer shoots. HOWEVER, the real danger in using 3rd party is when your applying a PATCH to your camera. Thats what kills most cameras, although a sharp loss of power during recording probably isnt too good for your camera either. (I fully charge my kit battery and ONLY use that to flash my camera.)
Tasaraha, the only time your gonna see a battery level is when your using the kit batteries. Everything else wont show a level on your camera.
@peternap thanks buddy. sounds like playing on thin ice if you don't know how long the battery plays.
@tasaraha That's normal for 3rd market batteries. They aren't chipped for the display. I use Wasabi's and they are 100% reliable but I know about how long they last and swap long before I get there....and yes, when they're dead one of two things will happen. They may just shut down without saving the file or they may hold out until you hit the shutter button to stop recording, then shut down without saving the file.
It's good to save files often.
btw, speaking of third party batteries on page 15. I have one original battery and one third party battery. when i use the third party battery (DELTA 7.4V 950mAh for DMW-BLC12 li-ion) with my GH2, the screen does NOT show how much juice it has left. i've been really skeptic about it and haven't used it since. And even now, reading that someones GH2 died maybe for this third party batteries issue. hmm..
couple of flow motion 2.02 tests i did
@zcream Very creative! Loved the look of the slow motion on the spotlighted blue floor.
Flowmotion and Apple Motion on some of my mates at gym.
