@jhero thank you for replying that definitely help I believe it's because I'm using OSX 10.7.2 I'm gonna upgrade to 10.7.4 and see what happens.
Guys, I made
http://www.personal-view.com/talks/discussion/4336/blackmagic-test-footage-grading-discussions
So, you can post all your opinions, grading attempts, etc.
Dear Colleagues, thank you for all the information found in this thread! I am not such a sophisticated color grader or camara man as you are. I am just trying to do some good motion picture documentaries. I was working with a Sony HDV cam since 2005 that at the time had quite a good resolution then even if color corrections ect. are very limited. Unfortunately the lens messed itself up internally and as it is not a changeble lens I am stuck with a broken camera and need a new one. I am shooting in Cuba a lot, so I do not have the possibility to carry a monstar cam around with me.
I was watching at Canon 5D Mark III and Sony PMWEX1R besides the BM cinema camera. The Canon does great images and is handy but as with this camera I am missing a movable display to be more flexible when shooting.
I am wondering about the following: 1. If I am away from home for two weeks, just a laptop and a camera, how do I manage to store the huge amount of data I will collect by shooting and how will I manage to shoot if I can not connect to a power source? 2. What voltage does it support (110-230 V)? 3. How do Canon lenses as EF 70-200mm f / 2.8L IS II USM interact with the camera or would you consider a different lens? Would this be an option as well, Tamron Std-Zoom AF SP 24-70mm f / 2.8 Di USD? 4. If I have to shoot at a concert or show with a dimmed atmosphere will I be able to get the light into it?
I am fascinated by the shots you got out of the BMC! With an up to date Apple infrastructure inkl. Thunderbolt I am quite sure that this camera is revolutionary for the entire Motion Picuture industry.
Chris
I doubt the BM is the right camera for you.. It seems completely counter-intuitive in relation to the work you do and the camera you seem to be used to.
Unless you per habit carry around filters, lots of storage and can manage with one or two lenses. The amount of data to store won´t be convenient for you if you like to have a lot of coverage. For raw you would use up 7.2 gb (unless I´ve calculated badly) / minute. For PRORES HQ it´s about 1/5th of that. Re: lenses the 70-200mm would mean approximately 150mm - 420mm full frame equivalent (give or take) so it might be of most use for you if you are a bird watcher.
Check out Sony´s new ENG camera. Not sure if the IQ holds up well enough for you, but it´s an option, nonetheless. The FS700 might be another good choice, consider getting an additional viewfinder for it. Get the bundled kit zoom lens if you are uncertain about lenses. Then you can bring an additional fast 50mm (or thereabouts) manual, adapted lens with you for situations where you really have to push low light performance.
For suggestions about lenses, check out the thread about video friendly lenses.
If you need a physically smaller camera (stealth should not be under-estimated); then the gh2 is great, budget friendly and the gh3 just around the corner. (pannys new zoom lens x 12-35 is perfect for documentary stuff).
That said, it could be quite interesting to shoot a documentary with a BM a-cam and a couple of small b-cams, like the compact rx100 or hx9v. Not for everyone or anything, though.
@RRRR Well, you never can learn enough ... I started with b/w fotography and ended up with 'cheap' film cameras. Remember, that the HDV wave of consumer cameras started in 2005 and I just stepped in then. No funding independent filmmaker ...
I see the step of BM as revolutionary for consumer cameras! I am working on a iMac i7 machine with Thunderbolt, FCP 7, FCPX working very well. Connected to a Promis Pegasus R6 (Extending option) I am doing fine when I am just around the corner ...
I will possibly have to learn quite a lot of new stuff, specially concerned lenses, where I missed the possibility to change them, but also about camera handling, as I am aware, this stuff is professional. Even so with all professionals, most of the time you can get into the subject pretty fast if you are interested about the stuff you are doing
I find quite a lot of stuff I can/want to arrange me with. I can arrange with avoiding low light situations, I also like to use the specific lens and using foto camera lenses for me looks like a good solution.
I might be wrong, but it looks to me like if you could use the BMC in many different situations. I can also separate Audio recording completely from the camera, using sync functions of FCP X for example.
Key for me is the question, when additional battery packs will come out. There are small discs with 2-4TB available with thunderbolt connection, so it is just about arranging well and your stuff doesn't need more space than a normal backpack ....
Re lenses: I don't get the conversion calculation you are talking about. Can you provide some links on background information about this subject?
Actually Sony for me is no option currently ... too connected with the Windows world ...
Thanx for your support in finding a suitable camera. Still not convinced it can't be the BMC. Alternative would be the 5D MIII ... Maybee both ...
Chris
Looking at the latest footage now. Even on vimeo it is very very nice. I am asking myself, what are all the other manufacturers thinking. From red to the Japanese manufacturers. If I were them I would be shitting myself. This camera will be like the dslr revolution mark 2. While some like Canon have tried to quell the original revolution it was the instigator by accident, by putting sub par models and trying to channel people to a new line of its more traditional very costly camcorder division. Others like Sony have put multiple models, that all have some sort of limitation depending on the price point.
Now we have a company that is putting some RAW camera at 5 time lower price than Canon 50 mbit 8 bit camera for example!!!! It is true that the BMC has some flaws that will prevent it from owing a big part of the market. Low light, sensor size for some. But in the qualitative film and commercial/advertising market it will be a big hit. People, DP etc will own this camera and then they might rent a C300 etc when need be. This camera has a bigger sensor and about the same DR that camera that have been use in two of the best film I have watch lately like black swan and The Hurt Locker.
So what will happen to this industry will be nice to watch. I sincerely hopes it hurts, looking at the C300 spec or the latest Sony NEX camera. Yes an eng style camera without built in ND. Yes sorry it will be in the next model for another $ 4000. So yes they can keep there last century 8 bit codec, there hunger strike bitrate and put it in every camera they want, we fortunately consumers are now free from that.
If BMD wants to corner the market, it won't be hard. Just drop the canon mount for something more universal -maybe even a bolt on/swap-out option and offer every type mount, or M4/3. Just do something to open it up for 3rd party PL adapters etc... Then fix the moire, and this is easily a major player in many ways. I was skeptical, and still am to a degree, but the more I play with the footage, the more impressed I am.
The lack of overcranking is still a big minus, but if I get handed one to shoot with, I won't slap the producer like I would with a 5D or 7D.
@shian Have you looked at the noise in the ISO1600 shot? My eye's not very experienced, but it seems very clean, doesn't it?
Gh2 pixel pitch 3.6µm where BMC 6.5µm.
I don't think the other manufacturers are too worried basically because the sensor size of BMC is small. If they had made APS-C that would be another story. Also, the camera will be too difficult for most people to use--it's for experts. The GH3 will have a larger sensor, let's see what the IQ looks like. I see an opportunity here for the big three to retool a DSLR or mirrorless to simply provide 2K output. I think it is the high end market that should be worried, but they in some ways are more threatened by hacked GH2.
@drdave how in the hell is the GH3 going to have a larger sensor?
I´m just saying it´s counter-intuitive for documentary work, that´s all. :) If I were you I´d wait around a bit to see what happens. Don´t get too attached to what camera has more support for what system. I have no issues with Sony cams and Mac whatsoever, although I don´t use avid and I´ve let go of FCP for Premiere. If you have a cam with a clean hdmi / hd-sdi + recorder combo you can record to prores directly, for instance.
re: the sensor, it´s s16 sized, meaning the crop factor relative to a full frame stills camera is over 2x. So unless you shoot a lot in the long end normally, you should be looking mainly at the range of 10-50mm lenses (from wide to normal tele range) to go with this camera. There´s not a lot of fast lens options in the wide end for the mounts that the BMD cam support.
Here´s an in depth article about what the BMD has to offer in relation to f.i. mkIII: http://magazine.creativecow.net/article/is-the-new-blackmagic-cinema-camera-the-hdslr-killer
Personally I would never consider mkIII if I didn´t have very strong intentions to shoot a lot of stills. It´s just not worth the trouble and the expense, in my view. Shallow DoF in it´s occasional glory; it can only be gotten rid of by reducing light to the sensor (stopping down). A smaller sensor; in-between s35 and s16mm film sits much better in terms of focus field control / wide open lens low light capacity than the vistavision size for filmic video and available light photography. Right now, there are plenty of very good cameras coming out on the market, so it may be good to have a wait and see approach.
I will most likely get a BMD cam soon. Although there are some issues (it´s not really perfect), it will be cheap in relation to renting an Alexa for short films, and the RAW option is absolutely perfect for that kind of work.
If you absolutely must have a new camera within the next month; get a gh2 and good glass that you can adapt to a variety of cameras (keep the glass for your REAL investment). That gives you the opportunity to get into the custom / modular approach and back into manual photography. Many new things will be unveiled at Photokina, no doubt.
Since this discussion strayed quite a lot off topic; I suggest we continue it elsewhere in specific topics!
@ Shian Yes, I hope they do listen because the Canon mount is very restrictive, more so with the sensor size. A shorter flange like 4/3 would have been much better, or a system with different faceplate/mount would have been better.
It was zero BMC for me as a Nikon user, but I just saw a forum post about cheap Chinese ebay adapter with aperture ring for Nikon G to Canon ef. So at least there is this solution. Far from elegant, but now I can think about buying a BMC.
My prediction is that projection adapters will live once more with this cam..
@johnnym I think it is between a yes and a no. For me it is not pure low light in the sense that it was not pure low light. There was still some ambient light and the actress was lit by the fireworks. There was also a lot of movement, so more difficult to see the noise as there are a ton of motion blur etc. So until we see more static scene and a bit darker environment we will have to wait to have a final judgement.
But there are other thing to take into consideration is relation of noise and resolution. What many see as clean like the 5d mark 3, is the SD (yes I mean SD) resolution of the Canon 5D at high ISO. Take that same resolution by applying some strong NR to the BMC footage to judge at same resolution to get a better idea.
I adapted all my nikons (7 primes and 2 zooms) with those Chinese adapters and they work great on all the Canon camera shoots I've been on. You need to put a few tabs of paper tape on them to get rid of any play, but once you do that you're golden..
@DrDave, I think that the sensor size is a little bit overdone. From the shot, you can see that you can get some nice shallow depth of field with this camera and nowadays the super shallow dof is getting a bit passe. People are realizing that the cinematic look is much more than only super shallow DOF. For me DR is as important, and this camera will show it.
@Brian202020, thanks for the tip. Do you know any video or pictures how to do it?
+1 The sensor size is really not that big a deal. People are just looking for reasons to nit-pick the camera. A crop factor of .5x from s35 is not going to make your stuff any better or worse. If you really think that having a true s35mm sensor, is going to, in any way, make your project more enjoyable to an audience... it might be time to reconsider what you're doing. I really think it's just scapegoating... just like all the "rolling shutter" and "I need ISO 32,000" scapegoating. People are just looking for excuses.
@bwhitz Well, rolling shutter - unlike sensor size - is a real problem if you wanna film heavy action stuff. You're really limited in what you can do. Just try filming "Saving Private Ryan"-like scenes with a BMCC or a DSLR and you'll fail miserably.
But sensor size really isn't that big of a deal, the EF-bayonet they went for has been a much weaker choice, especially for me since I'm a fan of extreme wide angle shots.
@bwhitz , I think that in everything, once you reach a certain threshold something becomes good enough. Looking at the footage and my experience working with the slightly larger gh2 sensor it was good enough. For sure, an s35 sensor would have helped a bit more, but we are closer to the s35 than to the 1/3 inch sensor size.
Nowadays it is too much about tech. At certain moment, something must be good enough and people should concentrate on the creation. Being a still photographer, I am shock when I see people complaining about clean 12000 ISO. Yes it is as if 12 000 ISO was a standard. They should just get am infrared camera.
Gamer and other Red shot films have rolling shutter galore... and it's not the least bit distracting. I bet the audience would think you were crazy if you even tried to explain what rolling shutter was to them. It would be nice to not have it, of course, but some people talk about RS as if thier films would suddenly be "pro quality" without it, when it really has nowhere near that level of impact on the final product.
Yep. Agreed. I think we might actually be seeing more "gear blame" as RAW shooting video becomes affordable. People who buy into the BM workflow, and still aren't turning out good products, are just naturally going to blame the fact that it's "not real s35mm" or "it ONLY goes up to ISO 1600". Nobody want to think that it might just be the fact that they're not creative or talented enough.
Because in the end, when you look at hollywood and other mainstream productions, you looking at the product of TALENTED people... not just "skilled" people who put in X amount of hours and have "pro" sets they work on. There's definitely a sense of "gear-hubris" these days.
I guess I'm the only one that finds it funny when GH2 owners complain about the Magic Cam sensor being slightly smaller...
Anyway, pick your poison and drink it. If you cant' see the advantages this camera has over anything else under F3/C300 territory, cool, continue to shoot with what you have. =] No harm, no foul.
@Shian -- Barring there's nothing weird in the nose of the camera, trust, lens mount options will be available from a third party source pretty soon. Mark me as one of the firsts to start shooting M4/3 and Super16 on this sucker the day it can happen.
