Are you saying this meter is wrong?
It can be good, for tungsten.
Led and fluos require full spectrum measuring that this thing can't do.
Also this is the reason why adjusting simple white balance you can't get rid of this light issues.
"The Minolta color meter II had its peak in the pre digital era, and was found in a lot of photography studios. They used to color correct slide films to remove color cast. Now with the digital era the color meter has made a comeback, at least it has for me. Being able to measure the color temperature (Kelvin) you get accurate white balance, and you spend less time post processing your pictures. "
http://www.momentcorp.com/review/colormeter.html
Are you saying this meter is wrong? Is it a calibration issue?
IMO GH cameras tend to shift plant greens towards khaki. So the problem might be not just about the white balance. Try to use Vibrant color profile while shooting mother nature instead of Standard or Smooth, or specifically yellowish Nostalgic. Vibrant has less dynamic range and is a bit oversaturated but the greens look more like greens with it, and you may dial saturation down as well or desaturate in post.
Not all grey cards can be trusted to give accurate white balance
Yep, but bad ones are not very easy to find now.
Except may be some cheapest paper ones.
Not all grey cards can be trusted to give accurate white balance.
I use the older version of the WhiBal card...
My dream: Gh3 by internal kelvin meter. :)
No such thing as Kelvin meter exist.
Some tools make estimation about color temperature. But it is estimation, that can be wrong, for example, with leds and fluos.
Try this
http://www.ebay.com/sch/i.html?_nkw=collapsible+grey+card
It is just usually more useful. Or get small hard card.
I do not know how it is related to grading?
Most accurate method is to set it by gray card or entering kelvin value.
