I got my answer, guys. Thanks! In FCPX you select the shot in the timeline; info in the inspector; 'setting view' in the bottom left and then the "field dominance override" is accessible and the drop down lets you choose from unmodified, progressive, upper first, lower first. Thanks again
Check Out PSF (Progressive segmented frame) this is how the Gh2 handles Proggressive in HBR It is interlaced kind of but it does not do Upper and lower Fields both Fields are the Same http://en.wikipedia.org/wiki/Progressive_segmented_Frame
60i wrapper to true 30p - put your clip in a 30p timeline. In adobe, modify/interpret footage, in fcp (not sure about fcpx) you do it via cinema tools. Open the clip in cinema tools, there is a conform button below. It must be incorporated somewhere in fcpx. Look around for conform option.
Now 1080p30 to 1080p24 is a different cup of tea.
There is no field dominance, as the HBR footage isn't really interlaced. You need to figure out how to tell FCPX that the footage is progressive. I'm a PPro user so I can't tell you how!
