AN "Valkyrie", GOLGOP3-13, GOP3ZILLA, natural, Freeze-less Reliable All-round GOP3 Settings :-)
  • 1001 Replies sorted by
  • Youve got the best looking GOP3 out there for sure :-)
  • @driftwood Thanks mate! :-) Being praised by you is gladdest for me.
  • @bkmcwd Mate, I just love your steadicam work. Absolutely terrific. Youve mastered it. :-) Great looking settings - well done.
  • @ Silent users of my settings :-)
    UPDATE: I have already released new experimental "GOLGOP3-13-MAX_EX_Standard_BETA6" setting.
    *Since the BETA5 is too agressive to use with Panny X12-35 in FSH and HBR, I detuned them.
    *Compared with BETA5, FSH and HBR are set as the slightly safe for codec stopping under high stressed scene in BETA6.
    I release new experimental "GOLGOP3-13-MAX_EX_Standard_BETA5" setting.
    *Compared with BETA4, FSH and HBR are set as the slightly safe for codec wavering under high stressed scene in BETA5.
    This EX matrix modified somewhat mildly from Sedna is optimized to GOLGOP3-13. This matrix has the middle character of SednaAQ1C and a stock. In this setting, the lowest possible "qp" is always arranged appropriately. It has adjusted so that "the level lines of the high qp macroblocks leading to image quality degradation" may hardly appear. And, it has also adjusted so that "qp" lower than "Sedna version" can be used without a codec wavering. Furthermore, priority is given to a motion over the static in 720p.
    IMO, I think that it will be an unstable setting which can not be expected when it stops recording if it tries to use 70M in 720/60p. Therefore, I give priority to the stability at which recording does not stop by any means in 720/60p. Only in 720/60p, the actual maximum bit rate is under 55M from such a reason.
    *Deblocking tables are substituted by your liking.
    Special thanks to @syoushow!
    Please try it!
    NOTE:
    *Although bit rate setups are quite high, the bit rate which actually appears are lower than these. Since the actual bit rate changes by the object to shoot, please confirm by yourself.
    *24H and 24L are high quality 3GOP setting with super mega size I-frames.
    *24p80%(30p) is available in 24H & 24L both.
    *In PAL Mode, I especially recommend you use with SanDisk 95MB/s 64GB SDXC card strongly.
    *In camera playback is sometimes not available in 24p. In other mode, available after reboot the camera.(Not tested full yet, but probably)
    *EX Tele works.(Not tested yet, but probably)
    *Spanning in 24H, 24L with SanDisk 95MB/s 64GB SDXC Card. In other mode, need test.
    Please download original raw data from vimeo and check actual IQ.
    1297 x 633 - 194K
    1298 x 634 - 203K
    1297 x 634 - 197K
    bkmcwd GOLGOP3-13-MAX_EX_standard_BETA5.zip
    1K
  • These are the samples of GOP3ZILLA_ST_V2_BETA5.
    *Please DL original raw data from vimeo to look the REAL IQ.
    *These videos are only samples for image quality.
    *The level line of the high qp macroblocks has not appeared even in the high contrast scene. :-)
    Sorry! The samples of "night" are not with ISO3200 but ISO1600.
    1295 x 634 - 203K
    1298 x 633 - 194K
    1297 x 632 - 187K
    1297 x 633 - 203K
    1297 x 632 - 194K
  • @Wilbo @Tobsen
    Thanks for using my settings and you are welcome! :-)
    Since I am now on short trip, I cannot look your footages. I will do tomorrow night.
    @sohus Have you tried 720/60p of GOP3ZILLA_ST or natural_st? I think that these are safe settings.  My latest BETA5 of GOP3ZILLA_ST2 is also stable in all mode. IMHO, 720/60p is available only with max bitrate of about 55M at least in Low GOP. The actual bitrate of my 720/60p is set to about 55M.
  • @bkmcwd We shot this short portrait in April using the AF101, the GH2 with on of your GOLGOP3 settings and Voigtländer and Nikon lenses. Thanks a lot for your work!
  • Hi @bkmcwd !
    I'm a long time lurker and first time poster. I just wanted to share a little video I shot at a NASA JPL open house a week or so ago with the GOLGOP3-13_SednaAQ1C_V2.1_BETA setting (I think you posted this setting in April?)... not the best camera work and editing/coloring I'm sure, but I thought the subject matter was interesting ;)
    Anyway I particularly like to use your settings along with Driftwood's and wanted to say thank you to you, @Driftwood and @Vitaliy_Kiselev for all the hard work you've put into making the GH2 shine far brighter than it was intended to, and for generously sharing your accomplishments with all the average guys on this site... and yes, I've donated :)
    Cheers!!
    -Will
  • @subco Thanks for the tutorial and the file. I´m going to test it now.
  • @ Silent users of GOP3ZILLAs :-)
    I release new experimental "GOP3ZILLA_standard_V2_BETA5" setting.
    *Compared with BETA4, FSH, HBR and SH are set as the slightly high frame limit in BETA5.
    In the modes other than 24p, it has improved so that the same frame size as a MAX version can be used. Of course, stability is taken into consideration by top priority.
    Please try it!
    NOTE:
    *Although bit rate setups are quite high, the bit rate which actually appears are lower than these. Since the actual bit rate changes by the object to shoot, please confirm by yourself.(Max bit rate in 24H = around 100M probably)
    *24H and 24L are high quality 3GOP setting with mega size I-frames.
    *24p80%(30p) is available in 24H and 24L both.
    *In camera playback is available in 24p. In other mode, Sometimes available after reboot the camera.(Not tested full yet, but probably)
    bkmcwd GOP3ZILLA_standard_V2_BETA5.zip
    935B
    1299 x 634 - 189K
    1297 x 633 - 188K
    1296 x 633 - 184K
    1296 x 631 - 167K
  • These are the ISO3200 samples of GOLGOP3-13-MAX_EX_BETA4.
    1297 x 632 - 190K
    1297 x 633 - 198K
  • Since the weather was bad, the NTSC versions the other day are not compared, but these are the samples of PAL.
    1297 x 634 - 202K
    1295 x 633 - 193K
  • @subco Thanks for the info. Where I can get your "ini" settings for gf2?. I do not know what to do with the link text. Thanks
    I release new experimental "GOLGOP3-13-MAX_EX_Standard_BETA4" setting.
    *Compared with BETA3, FSH and HBR are set as the slightly high bit rate in BETA4.
    Please try it!
    NOTE:
    *Probably, 24p80%(30p) is available in 24L only.(In 24H, need test)
    *In camera playback is sometimes not available in 24p. In other mode, Sometimes available after reboot the camera.(Not tested full yet, but probably)
    bkmcwd GOLGOP3-13-MAX_EX_standard_BETA4.zip
    1K
    1298 x 633 - 196K
    1297 x 633 - 194K
    1296 x 634 - 197K
    1297 x 632 - 191K
    1297 x 634 - 177K
  • @Bonzai
    Thanks for feedbacks always! :-)
    BETA4 is due to be released by the end of today.
    "I was a bit disappointed with BETA 3 as the shadows looked a bit 'muddy' compared with previous GOLGOP3 -13*** releases."
    Is it the stock matrix version which you compared with BETA3? EX matrix version which I am making now tends to make it a little mild compared with stock versions. The stock versions are the optimal if you are feeling serious consideration of resolving. Furthermore, I think that it is GOP3ZILLA_Standard series that is most excellent in a feeling of resolving in any situations.
    I am going to make 24p of BETA4 the same as BETA3. However, since my friend is also making the next experimental matrix, a different setting will be released soon.
  • I discovered the BETA4 Vimeo post a few hours after it was posted. However without a link to the "Custom Settings" there wasn't much more I could do but wait... I was a bit disappointed with BETA 3 as the shadows looked a bit 'muddy' compared with previous GOLGOP3 -13*** releases. You can bet I'll test it ASAP :-)
    Since HBR of "GOLGOP3-13-MAX_EX_Standard_BETA3" was too mild a little, I am working on next BETA4 version now. I plan to release it tomorrow.
  • @subco
    Yes! I remembered that you were the person who is using GOLGOP3-13 in GF2. :-)
    Thanks!
  • @nachelsoul
    Thanks for getting interested in my settings. :-) However, since I do not have GF2, I am sorry to be unable to reply to your question. On the contrary, I am glad, if it teaches when it can use. There was a user who removes the portion which corresponds to 24p from my setting, and uses in GF2 previously.
  • bkmcwd, please could you tell me if some of your settings works in GF2?. Thanks for your stunning work
  • These are the results of the test with BETA3 by my friend. Please observe the narrow ranges of qp. The codec is not wavering in the high stressed scene. :-)
    On the other hand, lower qp can be used under the lowlight.
    1297 x 633 - 89K
    1297 x 633 - 93K
    1297 x 633 - 105K
    I release new experimental "GOLGOP3-13-MAX_EX_Standard_BETA3" setting.
    This EX matrix modified somewhat mildly from Sedna is optimized to GOLGOP3-13. In this setting, the lowest possible "qp" is always arranged appropriately. It has adjusted so that "the level lines of the high qp macroblocks leading to image quality degradation" may hardly appear. And, it has also adjusted so that "qp" lower than "Sedna version" can be used without a codec wavering. Furthermore, priority is given to a motion over the static in 720p.
    Please try it!
    NOTE:
    *24p80%(30p) is available in 24L only.
    bkmcwd GOLGOP3-13-MAX_EX_standard_BETA3.zip
    1K
    1296 x 633 - 177K
    1296 x 633 - 181K
    1297 x 632 - 184K
    1297 x 633 - 183K
    1296 x 632 - 171K
  • Now, I am working on the GOLGOP3-13-MAX with new EX matrix. This experimental matrix made by my friend is very suitable for GOLGOP3-13. I am going to release it soon. :-)
  • @karl
    Thanks for reply and for explaining my settings! :-)
    @rapsoe
    Many thanks for your report back! :-) I am glad if any impression is told to me.
  • @kndkndknd
    Thanks always! Since I lived in Yoyogi before, I felt it nostalgic. :-)
    I think that the result with pany 14mm is not bad.
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
