This topic is decicated to my direct requests to make specific testing.
As all Pro topics it is intended to testers who want to help and understand that they are doing. If you do not understand, either ask or just read and wait.
Active points: * Try to format SD card using exFAT file system * Check how it works in GH2 * Combine two large MOV files making them >2Gb, and >4Gb. Check if they can be played back in camera.
Set 50Mbit. But this time adjust 1080p High Top Setting (in testers section). Start at 65000 and go down. See how it behaves. Always remember about binary search as it saves your time :-)
>should I set 24H bitrate at 22000000 or 42000000? You can see that I mention "throttled value". This is large bitrate setting that results in very low, improper, bitrate. Look at other posts here to understand proper setting.
"Now set bitrate at the throttled value and keep it constant But this time adjust 1080p High Top Setting (in testers section). Start at 65000 and go down. See how it behaves."
What card did you use at 60mill? For me it didn't write at all crashing, but at 61m and above it wrote as you described. I was on Dana Elec Class 10, card. Don't have my cam to test more until monday.
Thanks. Now set bitrate at the throttled value and keep it constant But this time adjust 1080p High Top Setting (in testers section). Start at 65000 and go down. See how it behaves. Always remember about binary search as it saves your time :-)
For 24H there is definitely something going on at 60000000. For 61, 62,63,64 and 65 mill 24H the GH2 records the codec crusher test chart perfectly for as long as I want but in streamparser I see those clips have been throttled down to 4-5Mb/s as you describe. But at 60000000 the GH2 recording stops in 2 seconds with the familiar 'write - performance limitation error' which seems to indicate the throttling mechanism has stopped and it's actually trying to write the higher data rate but can't. All this is with only 24H set to 60mill and absolutely nothing else set. Will do more testing under 60mill in a.m.
* This mirrors my experience with the 24P 3 GOP patch on the other thread, whenever I tried to go above 60mill for 24H it didn't work no matter what I set the tester patches to.
